Folder Options
iRawr
@irawr-7ejtdp โ€ข Oct 25, 2024
could someone help me about this folder option because I accidentally hid my folder in my drive d.. and I can't unhide it because I can't see it at the moment.
it says I can unhide it in folder options in the tools section but it doesn't show the folder option.
even in the control panel, there's no such icon for folder option.
can anyone help me please? I'm running on windows xp.
  • komputergeek
    @komputergeek-Yf5hJ4 • Apr 2, 2009
    Try using attrib command.
    attrib -s -h <filename>
  • iRawr
    iRawr OP
    @irawr-7ejtdp • Apr 2, 2009
    awwwee.. how to use attrib command?
    can you show me how please?
  • scorpionmaks
    @scorpionmaks-rnZBIQ • Apr 2, 2009
    iRawrcould someone help me about this folder option
    Open D: drive and go to "Tools" option in the uppermost toolbar . You will find it there.
  • iRawr
    iRawr OP
    there's no folder option on the tool option sorry to say :x
    dunno why but there's only 3 options I can see..
    โ€ข map network drive
    โ€ข disconnect from network drive
    and
    โ€ข sychronize
    no folder option..
  • scorpionmaks
    Ok .. then try this..
    *open command prompt
    *go to D: drive
    *and use the command
    *and check back in D: drive ๐Ÿ˜€
  • shalini_goel14
    @shalini-goel14-ASmC2J • Apr 2, 2009
    komputergeekTry using attrib command.
    Good command . Is there anything similar for "folders" ?
  • ms_cs
    @ms-cs-Ab8svl • Apr 3, 2009
    Simple way ,,,try this...
    Just right click on your D drive,select search ...It will display all the files and folders in the drive...Your hidden file or folder will be shown but it is somewhat shaded ...You can again right click on that particular folder and unhide...simple..๐Ÿ˜€
  • Anil Jain
    @CrazyBoy • Apr 3, 2009
    I do not think it will show the hidden files. does it?
  • Prasad Ajinkya
    @prasad-aSUfhP • Apr 3, 2009
    iRawrthere's no folder option on the tool option sorry to say :x
    and
    โ€ข sychronize
    no folder option..
    I hope I am wrong, but methinks that you are infected.
  • komputergeek
    @komputergeek-Yf5hJ4 • Apr 3, 2009
    shalini_goel14Good command . Is there anything similar for "folders" ?
    Same command can be used for folders by adding some parameters:
    /D for folders
    /S for processing all subfolders.
    Command :
    attrib -s -h <folder_name> /s /d
  • komputergeek
    kidakakaI hope I am wrong, but methinks that you are infected.
    I think you are right.
  • iRawr
    iRawr OP
    @irawr-7ejtdp • Apr 7, 2009
    awts. I dont think my computer is somewhat infected because I just reformatted it.
    weird because before I reformatted it, there's still a folder option on the tool but after I reformatted it.. it disappeared.
    it is somehow connected to my new OS?
  • Anil Jain
    @CrazyBoy • Apr 7, 2009
    Can you repair you windows system... ? Looks weired but it does helps sometime.
    -CRazy
  • yamrajbhalla
    @yamrajbhalla-ZPvBoL • Apr 8, 2009
    friend go to regedit in run hklm\software\microsoft\windows\currentversion\explorer\advance\folder\hidden\showall
    and there change the cheked value to 0 okies and its done
    and if ur folder options ver disabled than get the below registry
  • engineer_vinay
    @engineer-vinay-vETp5V • May 4, 2009
    yes, your pc is virus-infected.
  • slashfear
    @slashfear-tSWzpz • May 5, 2009
    Hi iraw,
    Yes your PC is infected and you can get back the contents of hidden folder in a simple way if you know the name of the folder (at least an approximate name)
    -> GO to D: drive then click on search
    -> Then click on advanced search option and check the "search hidden files and folder option"
    -> Then give in the folder name what your searching for (that should be the hidden folder name)
    -> Then click on search, thats it......! you will get the content of the hidden folder
    Now just right click on the folder and unhide the folder. your done buddy๐Ÿ˜‰
  • RajdeepCE
    @rajdeepce-7UdrG8 • May 13, 2009
    You are infected with worm, it is not a virus. It is perhaps W32.Brontok.A worm. Try download some Brontok worm remover by searching in google. It worked for me cause I too affected by this worm and my folder option get disappeared. But I disinfected my pc with worm remover and now my folder option works healthy.
  • yogesh_dhiman
    @yogesh-dhiman-KMW24I • May 18, 2009
    i think its a regestry problem dude u have to check ur regestry ort reinstall ur window nd scan virus . Virus is make a file in to ur pc regestry.
    for more information contact 9888927692 ,
