  • narayana murthy
    @narayana-z4W16q Dec 30, 2011
    fully loaded means it has high current taking so check for the output power and input power as it is a.c and it is transformer it will have frequency of 50hz.
    power=vicos(phi)
    efficiency=output power/input power
    so u can find efficiency at what ever rating is
  • aarthivg
    @aarthivg-HH344f Dec 30, 2011
    narayana murthyfully loaded means it has high current taking so check for the output power and input power as it is a.c and it is transformer it will have frequency of 50hz.
    power=vicos(phi)
  • aarthivg
    is it possible to overload transformer up to 150 percent?
  • narayana murthy
    ofcourse depending on rating and losses will be heavy in such case magnetic saturation also occurs here
  • aarthivg
    @aarthivg-HH344f Dec 31, 2011
    narayana murthyofcourse depending on rating and losses will be heavy in such case magnetic saturation also occurs here
    Is it a feasible system if we overload a transformer up to 150 percent for certain period of time and then allowing it to share the load with a another transformer by parallel operation
  • narayana murthy
    @narayana-z4W16q Dec 31, 2011
    as per my knowledge it should not overloaded to such extent
    @other ceans: correct me if i am wrong
  • lal
    lal
    @lal-R60Xjx Dec 31, 2011
    Usually electrical devices are designed to work at an overloaded condition without break down. That is a transformer or motor or any AC machine (except fuses and CBs😁 ) can withstand a power surge that is beyond the rated value. The device continue to work perfectly without damage at power above rated value. This is to prevent the possible damages that can occur when a fault happens in the circuit.
    But, the over power, that the machine can withstand without damage depends solely on the design and operating conditions which is based on its applications. A transformer can withstand a lot more power capacity if extra cooling techniques are employed. Factors like insulation breakdown and so on should also be considered while doing so.
  • narayana murthy
    i think lal u missed one thing surges are only for fraction of second but here topic is about overloading for some considered time.
    there is a problem here at such condition overload makes breakdown of insulation and there is a problem of magnetic saturation as current increases flux increases leads to magnetic saturation
  • lal
    lal
    I think, the surge that you mentioned is lightning surge and faults friend. I wrongly used the word 'surge' there 😁 My intention was to mean 'an increase'.
    By the way, overload wont induce a breakdown. If the voltage increases beyond the maximum withstand-able value of insulation, it happens. Over load will cause large increase in temperature that would lead to damage of machine if proper cooling methods are not used. And there would be magnetic saturation problems. But machines are designed to work at more than hundred percent of the ratings.
  • narayana murthy
    @narayana-z4W16q Jan 1, 2012
    may be lal so we can conclude that this is suitable for over loading???
  • aarthivg
    @aarthivg-HH344f Jan 1, 2012
    lalI think, the surge that you mentioned is lightning surge and faults friend. I wrongly used the word 'surge' there 😁 My intention was to mean 'an increase'.
    do you mean to say, overload does not cause insulation failure?
  • lal
    lal
    @lal-R60Xjx Jan 4, 2012
    Sorry to be late back here..
    I meant, overloading won't induce an insulation breakdown. But it can cause insulator damage by increase in temperature.
    @nm, yeah with suitable cooling techniques, a transformer can be overloaded.
  • aarthivg
    @aarthivg-HH344f Jan 4, 2012
    lalSorry to be late back here..
    is it feasible to overload a transformer
  • lal
    lal
    @lal-R60Xjx Jan 5, 2012
    I am not quite sure about that buddy. Will try to find out more 😀
  • aarthivg
    @aarthivg-HH344f Jan 5, 2012
    lalI am not quite sure about that buddy. Will try to find out more 😀
    ok. thanks
  • narayana murthy
    @narayana-z4W16q Jan 8, 2012
    actually overloading causes high temperatures due to increase in losses but according to me it shouldn't be overloaded but in some conditions situations demands at such time we can use answer given by lal
  • aarthivg
    @aarthivg-HH344f Jan 9, 2012
    narayana murthyactually overloading causes high temperatures due to increase in losses but according to me it shouldn't be overloaded but in some conditions situations demands at such time we can use answer given by lal
    just consider this scenario. there are 2 transformer connected in parallel let it be t1 and t2. during flat period, t1 operates, and t2 is in off position. when the demand increases, transformer t1 is overloaded up to 150 % for some time. and then t2 is switched on.so that load is shared between them as 75 %. this eliminates no load losses and bus fault current. is it a feasible idea?
  • narayana murthy
    @narayana-z4W16q Jan 10, 2012
    aarthivgjust consider this scenario. there are 2 transformer connected in parallel let it be t1 and t2. during flat period, t1 operates, and t2 is in off position. when the demand increases, transformer t1 is overloaded up to 150 % for some time. and then t2 is switched on.so that load is shared between them as 75 %. this eliminates no load losses and bus fault current. is it a feasible idea?
    yes ofcourse
  • aarthivg
    @aarthivg-HH344f Jan 11, 2012
    narayana murthyyes ofcourse
    i have planned to do project on this basis.
  • narayana murthy
    @narayana-z4W16q Jan 13, 2012
    aarthivgi have planned to do project on this basis.
    nice then please give your progress
  • aarthivg
    @aarthivg-HH344f May 5, 2012
    At last this idea end up successfully. Thanks to all
    It has been forwarded to tneb.
