Find the number puzzle.
There is a number less than 3000 that when divided by 2 leaves a remainder of 1, when divided by 3 leaves a remainder of 2, when divided by 4 leaves a remainder of 3, When divided by 5 leaves a remainder of 4, when divided by 6 leaves a remainder of 5, and so on up to nine.
What is that number?
Please provide step by step solution to this problem.
  • kedarjk
    @kedarjk-R7FdZW • Dec 3, 2013
    2519
    I wrote a simple python program to find it out. ๐Ÿ˜‰
    @abrakadabra • Dec 3, 2013
    kedarjk2519
    Please share the script, friend! ๐Ÿ˜
  • kedarjk
    Its no brainer...
    for i in range (1,3000):
    if i%9==8:
    if i%8==7:
    if i%7==6:
    if i%6==5:
    if i%5==4:
    if i%4==3:
    if i%3==2:
    if i%2==1:
    print "This is the number: "+ str(i)
    I was curious to check if there is really such number, so wrote a simple script. There must be some other logic to find it out.
    @anoop-kumar-GDGRCn • Dec 3, 2013
    That's an bad programming, number of loops will be 2519.
    This is class 8th problem which is calculated by following method, It's like following
    LCM (reminders) *x - GCD(Numbers) until you find the solution. x is an Integer.
    I don't remember that exact method.
  • Alok mishra
    @alok-mishra-E4tgN8 • Dec 5, 2013
    ianoopThat's an bad programming, number of loops will be 2519.
    its n*LCM(divisor)-(difference Between divisor and remainder) , n is any natural number .
    @anoop-kumar-GDGRCn • Dec 5, 2013
    Another example of this question is
    find x such that
    reminder is 2 when divided by 3,
    3 when divided by 4,
    1 when it's 5.
  • smorgasbord
    @smorgasbord-Aq7fYb • Apr 23, 2014
    Ankita KatdareThere is a number less than 3000 that when divided by 2 leaves a remainder of 1, when divided by 3 leaves a remainder of 2, when divided by 4 leaves a remainder of 3, When divided by 5 leaves a remainder of 4, when divided by 6 leaves a remainder of 5, and so on up to nine.
    A number when
    divided by 2 leaves a remainder of 1 = divided by 2 leaves a remainder of 1
    divided by 3 leaves a remainder of 2 = divided by 3 leaves a remainder of 1
    divided by 4 leaves a remainder of 3 = divided by 4 leaves a remainder of 1
    divided by 5 leaves a remainder of 4 = divided by 5 leaves a remainder of 1
    . = divided by 9 leaves a remainder of 1
    Which means we need LCM of 2,3,4,5 ( 60 ), 7 ( 420 ), 8 (420*2=840), 9 ( 840*3 ) = 2520 ... and something.
    if we need all the right hand side of the ='s to be set right we need to add one to 2520, but we need all the left hand side of the ='s written above to be true, so need to subtract one from it.
    2519.
  • smorgasbord
    Hell! i made an egregious error:
    A number when
    divided by 2 leaves a remainder of 1 = divided by 2 leaves a remainder of -1
    divided by 3 leaves a remainder of 2 = divided by 3 leaves a remainder of -1
    divided by 4 leaves a remainder of 3 = divided by 4 leaves a remainder of -1
    divided by 5 leaves a remainder of 4 = divided by 5 leaves a remainder of -1
    . = divided by 9 leaves a remainder of -1
    Which means we need LCM of 2,3,4,5 ( 60 ), 7 ( 420 ), 8 (420*2=840), 9 ( 840*3 ) = 2520, & -1 = 2519
    sorry. ๐Ÿ˜›
