Extracting images from .avi file
saurabh.geek
@saurabhgeek-njYKHe โ€ข Oct 13, 2024
Hi,
I want to extract image from the .avi file & save the images into jpg format. I had gone through some matlab functions like getframe() etc, but was unable to implement this thing.
Could you provide me with code which be a solution to this problem.
Best Regards,
Saurabh
    @harshad-ukH5ww • May 14, 2009
    i had seen some software for this kind of conversion but code...No idea
  • arhs
    @arhs-as8Kf1 • May 14, 2009
    let's name "test.avi" your file.
    first read it: obj1=mmreader('test.avi');
    then you can get any frame from "obj1" with the following command:
    I=read(obj1,X);
    where "X" is the displied frame of the image "I"!
    this will be ok for realeases after '08 for sure!
    sorry for my english and i hope this will work for you!
    pleased that i found you guys!!!๐Ÿ˜
  • Rifaa
    @rifaa-NaWZZ4 • May 14, 2009
    If u want to extract a still image from an AVI, I donno abt MLAB, but you can use Cyberlink Power DVD or Sony Vegas. This is what I use mainly to grab still frames from any video file.
    Snapshot also a good freeware
  • RajdeepCE
    @rajdeepce-7UdrG8 • May 15, 2009
    As per my opnion Auroura Media Workshop is the best cause if you want to extract images from avi file than just load the avi file and set how many frames you want to capture. Then its done!!!! It will save the images in any format and it will save the images in desired folder.
