explaining CE-AMPLIFIER to beginner
karenclave
@karenclave-7MDi4s โ€ข Oct 26, 2024
*water from tank on third floor of building flows down to tap on ground level from a pipe.
*when a valve is in first floor to control the flow of water to tap on ground.
*by varying that valve then pressure of water on tap of second floor vary!!
here,
water=current :
pipe=voltage
tankon third floor = collector(12V supply) :
valve=base(input/pressure)
tap on ground floor = emitter
tap on second floor= OUTPUT
is above good to explain to beginners as alternative???
please suggest me..if there is grammer mistake then correct it!!
it will help.
  • silverscorpion
    @silverscorpion-iJKtdQ • Dec 2, 2008
    I think you illustrate NPN transistor. Good analogy. What about PNP transistor?
  • karenclave
    @karenclave-7MDi4s • Dec 10, 2008
    ooops...
    is it only explaining NPN transistor??
    hv to study abt PNP transistor๐Ÿ˜’ but do anyone explain PNP??
    then how to explain function of CE-Amplifier??๐Ÿ˜•
