  • Excel Tip: Merging Two Cells Without Losing Data
    Administrator
    Updated: Oct 26, 2024
    Views: 1.1K
    CEans,
    Following excel tip might come handy at times. Say, you want to merge two excel cells without losing data -
    First Name
    | Last Name
    John | Lennon
    Paul | McCartney
    to single column like this
    Full Name
    John Lennon
    Paul McCartney
    You can do that by using Excel's CONCATENATE Function. Here's how -
    In any unused column, enter this-
    =CONCATENATE [A1, " ", B1]
    (Replace A1, B1 by the column numbers)
    Press tab and whoa your get what you want
    You can simply hover your cursor at the bottom right of the cell until + sign appears and then drag to copy the formula to all the cells.
    Works like charm and may save you lot of time in future. [​IMG]
  • Anil Jain
    MemberApr 2, 2009
    The_Big_K
    First Name | Last Name
    John | Lennon
    Paul | McCartney
    Full Name
    John Lennon
    Paul McCartney
    Oops Biggi !!
    Here concatenate will join the columns and will show First NameLast Name.
    I am puzzled that is there any way by which in 1st row I can see only the common value of the 2 cells 'Name' only.
    -Crazy
  • priti00
    MemberApr 10, 2009
    Let me try this and will let you know ... just a moment ... I am going to use this rite now ...
    Mate excel is showing this message - Not a Valid Name. I think I am missing something here. Will you please tell us more.
    ___________________
    #-Link-Snipped-# | #-Link-Snipped-# | #-Link-Snipped-#
  • Differential
    MemberApr 12, 2009
    crazyboy
    Oops Biggi !!
    -Crazy
    1) It will seperate First Name and Last name by a space as formula contains a space in concatenation! 😀
    2) Yes, you can see common value. But, elaborate your requirement a little more so that I can give you exact formula.
    Thanks!
