EvoMouse Lets You Click Without A Mouse
EvoMouse is definitely cuter than your current computer mouse and may soon replace it. Celluon, the creators of EvoMouse say that it's an advance mouse that will soon replace the need of a physical mouse and change the way you interact with your computer. EvoMouse can guess the gestures of your fingers and takes action without needing to physically move the mouse. EvoMouse works on any flat surface, occupies very little space, tracks your fingers and looks damn cute -
[โ€‹IMG]
EvoMouse uses two infrared sensors located in the eyes of the tiny animal-like device to lay out an area on the flat surface. Any hand gesture made in the area is instantly recognized by the sensors and appropriate action is taken. You can performa all your regular activities like click, doubleclick, move cursor, scroll,ย  select and even do multi-touch actions like zoom in and zoom out.
There's more you can do with evoMouse - drawing. Just move your hand within the sensitive IR area and you can draw! There's an optional keymat that can turn evoMouse into a virtual, full sized QWERTY keyboard. Celluon says that since evoMouse eliminates the need of a physical mouse, it can also reduce the stress caused by longer use of physical mouse. The device can be connected to your computer via bluetooth or USB which also takes care of charging the batteries inside evoMouse. The device is compatible with Windows, Blackberry & Symbian devices.
<object style="height: 390px; width: 640px;"><param name="movie" value="https://www.youtube.com/v/UZWLwjbJZ-s?version=3" /><param name="allowFullScreen" value="true" /><param name="allowScriptAccess" value="always" /><embed type="application/x-shockwave-flash" width="640" height="390" src="https://www.youtube.com/v/UZWLwjbJZ-s?version=3" allowfullscreen="true" allowscriptaccess="always"></embed></object>
What's your take on evoMouse.
Source: ++Celluon++
