Error in .Net Code
YashuAsha
@yashuasha-I5vI1n โ€ข Oct 25, 2024
here is my code to save and retrieve the word/excel/image/pdf files to sql database and display them in grid view using handler there is no error when i compile it but when i execute the code the following error occurs.
I have created SaveDoc table to store files in it with DocName,Type,DocData columns
The connection name 'ConnectionString' was not found in the applications configuration or the connection string is empty.
Line 38: </Columns>
Line 39: </asp:GridView>
Line 40: <asp:SqlDataSource ID="SqlDataSource1" runat="server" ConnectionString="<%$ ConnectionStrings:ConnectionString %>" Line 41: SelectCommand=" Select DocID, DocName, doctype from SaveDoc"></asp:SqlDataSource>
Line 42:
protected void btnUpload_Click(object sender, EventArgs e)
if (FileUpload1.HasFile)
string fileName = Path.GetFileName(FileUpload1.PostedFile.FileName);
string fileExtension = Path.GetExtension(FileUpload1.PostedFile.FileName);
string documentType = string.Empty;
switch (fileExtension)
case ".pdf":
documentType = "application/pdf";
break;
case ".xls":
documentType = "application/vnd.ms-excel";
break;
case ".xlsx":
break;
case ".doc":
documentType = "application/vnd.ms-word";
break;
case ".docx":
break;
case ".gif":
documentType = "image/gif";
break;
case ".png":
documentType = "image/png";
break;
case ".jpg":
documentType = "image/jpg";
break;
int fileSize = FileUpload1.PostedFile.ContentLength;
byte[] documentBinary = new byte[fileSize];
FileUpload1.PostedFile.InputStream.Read(documentBinary, 0, fileSize);
SqlConnection con = new SqlConnection(@"Data Source=localhost\sqlexpress;Initial Catalog=klausDB;Trusted_Connection=true");
con.ConnectionString = ConfigurationManager.ConnectionStrings["ConnectionString"].ConnectionString;
SqlCommand cmd = new SqlCommand();
cmd.CommandText = "INSERT INTO SaveDoc(DocName,Type,DocData)" + " VALUES (@DocName,@Type,@DocData)";
cmd.CommandType = CommandType.Text;
cmd.Connection = con;
SqlParameter DocName = new SqlParameter("@DocName", SqlDbType.VarChar, 50);
DocName.Value = fileName.ToString();
cmd.Parameters.Add(DocName);
SqlParameter doctype = new SqlParameter("@doctype", SqlDbType.VarChar, 50);
doctype.Value = documentType.ToString();
cmd.Parameters.Add(doctype);
SqlParameter uploadedDocument = new SqlParameter("@DocData", SqlDbType.Binary, fileSize);
uploadedDocument.Value = documentBinary;
cmd.Parameters.Add(uploadedDocument);
con.Open();
int result = cmd.ExecuteNonQuery();
con.Close();
if (result > 0)
lblmessage.Text = "File saved to database";
GridView1.DataBind();
protected void GridView1_RowCommand(object sender, GridViewCommandEventArgs e)
if (e.CommandName == "Download")
string fileName = string.Empty;
int index = Convert.ToInt32(e.CommandArgument);
GridViewRow row = GridView1.Rows[index];
int documentID = Convert.ToInt32(GridView1.DataKeys[index].Value);
SqlConnection con = new SqlConnection(ConfigurationManager.ConnectionStrings["ConnectionString"].ConnectionString);
SqlCommand cmd = new SqlCommand("SELECT DocName,DocData FROM SaveDoc WHERE DocID = " + documentID, con);
con.Open();
SqlDataReader dReader = cmd.ExecuteReader();
while (dReader.Read())
fileName = dReader["DocName"].ToString();
byte[] documentBinary = (byte[])dReader["DocData"];
FileStream fStream = new FileStream(Server.MapPath("Docs") + @"\" + fileName, FileMode.Create);
fStream.Write(documentBinary, 0, documentBinary.Length);
fStream.Close();
fStream.Dispose();
con.Close();
Response.Redirect(@"Docs\" + fileName);
Please help me solve this error.
  • [Prototype]
    @prototype-G9Gn5k • Aug 20, 2012
    Add Provider and try.
    ProviderName="<%$ ConnectionStrings:ConnectionString.ProviderName %>"
