  • electricity consumption
    schiZ0prEni
    schiZ0prEni
    @schiz0preni-Fztooe
    Updated: Oct 18, 2009
    Views: 1.1K
    Dear all,
    I just graduated as a mechanical engineering student and currently been working as a facility engineer which i've to cover all the systems in the building i.e hospital and commercial building in term of their maintenance,services,analysis as well as energy management.
    my question is, in central cooling system which has chiller,pumps,ahu,colling tower,heat exchanger etc.,which of the component should be turned ON first in order to minimize the electricity and maximum demand?there should be a sequence of series or order so that the consumption of energy can be minimized.
    will it makes any diff. if in term of electricity consumption i start the bigger unit 1st and follow up with smaller one compare to the opposite sequence?
    Thank you in advance!
    Cheers!
  • webappln
    MemberOct 20, 2009
    If your Electricity Consumption Per Month is 1000 Units (KWH),
    Your Annual Electricity Bill will be Rs.73,248
    Generation of this much electricity consumes 4,364 kgs of Coal
    CO2 Emission for Generation of this Electricity is 12,000 kgs.
    You require 552 Matured Trees around you to take care of exhausted CO2.
    Being You don't have Space left out to grow that much of trees and also not having Time to involve self in this activity.
    At least, you can reduce your Electricity Consumption to balance our mother nature.
