Electrical Engineering Explained In 5 Seconds!
PS: Not exactly a technical topic; but I thought this would be the most appropriate section because it's all about 'basics', you see.
Member • Nov 2, 2012
Administrator • Nov 2, 2012
Ultimately, Electrical engineering is all about Current, Voltage and Resistance; right?naveeeBut transformer doesn't applies this major law sir 😀 ????
Why not?naveeeBut transformer doesn't applies this major law sir 😀 ????
Except non linear devices all the other devices comes into this list onlynaveeeBut transformer doesn't applies this major law sir 😀 ????
Member • Nov 3, 2012
#-Link-Snipped-#jeffrey samuelExcept non linear devices all the other devices comes into this list only
😨 I am confused It is an entire lab manual of Harvard university and that tells all about many experiments in electrical but I am not getting your point here sirbioramani#-Link-Snipped-#
Got it sir thanks for clearingbioramaniNon linear issues are discussed. It was in extension to your post.
ya..... mutual inductance is playin a gr8 role in transformers..... ya i agree ur point 😀The_Big_KUltimately, Electrical engineering is all about Current, Voltage and Resistance; right?
sir transformer doesnt obeys ohm law......... am sure about it ..... .....becoz in transformer ratio....voltage and current ratio are inversely proportional sir 😀bioramaniWhy not?
You have to replace resistance by impedance, which is AC resistance in a sense.
Hey pal better not use SMS language here in forumsnaveeeya..... mutual inductance is playin a gr8 role in transformers..... ya i agree ur point 😀
And it does not obey wherenaveeesir transformer doesnt obeys ohm law......... am sure about it ..... .....becoz in transformer ratio....voltage and current ratio are inversely proportional sir 😀
Consider the two windings separately.naveeesir transformer doesnt obeys ohm law......... am sure about it ..... .....becoz in transformer ratio....voltage and current ratio are inversely proportional sir 😀
Even if we take Mutual inducatnce principle also there is Ohmic rule in itbioramaniConsider the two windings separately.
why not non linear devices?, all kind of devices accept this law right? or am i mistaken at some point?jeffrey samuelExcept non linear devices all the other devices comes into this list only
ok pal got it......i will change it 😀jeffrey samuelHey pal better not use SMS language here in forums
we leave that...... but according to ohms law...current and voltage should be directly proportional.. if we see in transformer ratio........ it is in inverse......why and how ???? thats the great doubt,,,!!!!! my lecturers told that is due to mutual inductance.. !!!!!!!!......could you please clarify me sir..... 😀bioramaniConsider the two windings separately.
Member • Nov 4, 2012
All Ohmic rules holds good for Linear devices onlyprashanth463why not non linear devices?, all kind of devices accept this law right? or am i mistaken at some point?
Hey friend you are failing to understand this each side the conversion takes place in terms of constant powernaveeewe leave that...... but according to ohms law...current and voltage should be directly proportional.. if we see in transformer ratio........ it is in inverse......why and how ???? thats the great doubt,,,!!!!! my lecturers told that is due to mutual inductance.. !!!!!!!!......could you please clarify me sir..... 😀
thanks samuel for clearing it out with a simple examplejeffrey samuelAll Ohmic rules holds good for Linear devices only
Diodes does not obey these laws cos current I is not proportional to Voltage applied V
My pleasure friendprashanth463thanks samuel for clearing it out with a simple example
okay okay ....... 😀jeffrey samuelHey friend you are failing to understand this each side the conversion takes place in terms of constant power
For an ideal transformer
VpIp=VsIs
This is a direct effect of Ohms law
Member • Nov 5, 2012
Power in primary equalling the power developed in secondary. Well, I dont think there is Ohm's law in effect there. Power is transferred by induction. Or say varying magnetic fluxes created by the primary winding linking with the secondary transfers power to secondary. Since almost the complete flux generated by varying primary current links with the secondary winding, the power transferred is very high too, almost cent percent efficiency.jeffrey samuelHey friend you are failing to understand this each side the conversion takes place in terms of constant power
VpIp=VsIs
