CrazyEngineers Archive
Old, but evergreen and popular discussions on CrazyEngineers, presented to you in read-only mode.
@070790vivek • 10 Feb, 2010
in a automobile every electrical equipment needs a earthing then how it provides?
is there any common wire which remains in touch with the ground or automobile body?
but in my sense the tyres are insulaters.then it can be earthed?
@piyushh • 10 Feb, 2010
good question
its not earth in actual sense....its the negative terminal of the battary which is connected to the body ...i guess its for simply saving the wires for negative supply
fr example..for conecting a horn we simply give a positive supply througt switch n give negative supply from any nearest metal part of vehicle
070790vivekin a automobile every electrical equipment needs a earthing then how it provides?
good question
@lal • 11 Feb, 2010
You dont have to earth a motorcycle's body. I mean a connection to the ground as you do in your homes.
@Codex Guides • 24 Feb, 2010
There is no earth ground on any vehicle. "Ground" is the negative terminal of the battery only.
Electrical equipment does not require an earth to operate. It requires a potential difference to operate. This is how battery-operated devices work; there is no earth, but there is a potential difference between the two battery terminals. If you toss your cell phone or GPS into the air, it still stays on, even though there is no possible earth reference.
The negative terminal is connected to the vehicle frame/body. This makes the entire frame of the car "ground". Motorcycles work exactly the same way.
Some cars end up having problems in their audio or ignition systems because these frame ground wires are too small or become corroded or damaged. Some performance enthusiasts even take the trouble to upgrade the wiring to heavier gauge cable and/or additional grounding points. Audio installers often battle sound problems related to lousy ground connections on the vehicle frame.
Earth grounds are nearly always for safety reasons. You need a place to dump electrical energy in case of a fault, so that someone touching the equipment will not become the conductive path and get shocked to death. The planet is a convenient place to shunt the energy, but it's not always a good place, as safety grounding engineers can attest.
- CG
Codex Guides: The World At Your Fingertips
- CG
@sasuke • 07 Apr, 2010
You can try improve your motocycle grounding system. For, example, i do on my car. In negative batery terminal (ground), i add wire connected to alternator body, head block engine, gearbox, abs system, amplifier audio system and ignition system. It have some different.
This is because it improve return path to negative batery. The current flow will be short instead need to flow through car body.
Note: need to use quality wire, big wire & shortest possible.
@rishabh9951 • 13 Apr, 2010
hey...i think ground is not the negative terminal its the third teminal which sends the leakage current direct to ground.......its that third terminal seen in the the pludge....cose when we on the switch the current also pass through negative terminal to comlete the circuit...
@vibhor_one • 14 Apr, 2010
I want to add a question in this particular discussion that what about earthing of ships? can anybody explain because of the reason that ship are always in contact of sea, could it be its return path where negative wiring are done?
@sasuke • 14 Apr, 2010
in electrical, there have AC & DC source/supply. In high voltage AC, i.e 230Vac & 415Vac, common terminal are Line (L), Neutral (N) & Earth (E). This earth is also call ground, and this earth is purpose for safety & leakage current.
For voltage DC, common terminal are Positive (+) & Negative (-). This negative is also call ground but this ground is NOT Earth.
This name may confuse our fundamental.
I think for ship, there dont have earthing system same as motorcycle & car because no connection to earth/ground.
@vibhor_one • 15 Apr, 2010
I don't agree with you, that ship does not have any earthing system for safely in equipments used in the ships which is very necessary, What say???
@sasuke • 15 Apr, 2010
may need to ask ship crew. Just check electrical appliance is that use earth wire or not.
@vibhor_one • 16 Apr, 2010
Hi Sasuke,
Yes definitely every electrical appliance does have earthing for its safely which can rather be the body itself which necessarily does not mean it is connected to an earth wire. My query and concern is about the safely measures that should be on a ship as can earthing be done to save human body from electrical shock.
If you could just help me in clarify my doubt regarding above, I would be gradeful to acknowledge your answer.
With due regards,
Vibhor Mittal
With due regards,
Vibhor Mittal
@aj_onduty • 27 Aug, 2010
https://www.crazyengineers.com/forum...ng/33835-what-concept-live-neutral-wires.html
You Desperately have to view thisrishabh9951hey...i think ground is not the negative terminal its the third teminal which sends the leakage current direct to ground.......its that third terminal seen in the the pludge....cose when we on the switch the current also pass through negative terminal to comlete the circuit...
@Sarathkumar Chandrasekaran • 07 Sep, 2010
Could you please tell why earthing is done .i am an 1st year au engineer.pleasehelp me to understand...please.what is the use of it.
@aj_onduty • 07 Sep, 2010
@CSK AUTO
Kindly view the thread I have mentioned above. You can figure everything out yourself.
6k views
@Ankita Katdare · Aug 27, 2014
Swipe Telecom has launched a new smartphone called the Swipe Sense that has an inbuilt fingerprint sensor, a feature made popular with Apple's iPhone 5S and 5C smartphones. The Swipe...
3.5k views
@Dhananjay Harkare · Mar 6, 2015
We have already heard about companies like Tesla, Google, Apple and others working on self-driving cars, but now reports claims that Mahindra is going to join this elite league. Indian...
3.6k views
@Len · Oct 27, 2012
Is there any method to rebuild an 8086 microprocessor instruction from its opcode? Also how can we convert the instruction to the opcode? I am trying to build an emulator,...
4.6k views
@Kaustubh Katdare · Sep 5, 2013
Samsung Galaxy Note III's India launch date is September 25! At the time of unveiling the phone last night in Germany, Samsung's J.K. Shin announced that the phone will be...
4.3k views
@YUGA · Sep 8, 2008
HAPPAY ENGINEERS DAY,
I think We celebrating the ENGINEERS DAY on birth day(15-sept) of Mr.M.VISHWESWARAIH,who is first civil engineer. right?
6.5k views
