Downloading software bigger than available disk space
zaveri
@zaveri-5TD6Sk โ€ข Oct 16, 2024
Yesterday i was downloading a mechanical design software from the net.
But then a dialogue box appeared saying that the software required around 320 Mb , while i had only 207 Mb free on the hard disk. it asked whether to install anyway , to which i refused.
now what would have happened if i had agreed ? would my PC have crashed ?
    @thebigk Jul 22, 2012
    I'm assuming you're using Windows Operating System. Typically, when the application being downloaded or installed is larger than the available disk space, Windows throws an error informing about the limited space. But it offered to proceed anyway, in that case; the software installer would abort after being unable to extract the file to the disk. I doubt it'd cause your PC to crash.
  • Sahithi Pallavi
    @sahithi-oJZaYj Jul 22, 2012
    No Crash I think. As Bigk said just an error would display and then abnormal termination of the program.
    @anoop-kumar-GDGRCn Jul 22, 2012
    You file will not be downloaded and if you try to download file bigger than available space system will get stuck/hanged.
    Cleaning up temp file may create some space. try #-Link-Snipped-# small utility but still works .
  • zaveri
    @zaveri-5TD6Sk Jul 22, 2012
    Thank you guys.
  • Kedar Malwadkar
    @kedar-crbktt Aug 3, 2012
    Which software it was?
  • zaveri
    @zaveri-5TD6Sk Aug 3, 2012
    Kedar MalwadkarWhich software it was?
    ansys
  • Mayank25
    @mayank25-LzRqTU Aug 3, 2012
    Surely the system was not crashed !!!! but abnormal termination of program was held....
