@b-r-sain-4wDpAl • Apr 14, 2012
yes, a positive feedback is required. As oscillator does not use any input ideally so it uses positive feedback. When output is applied to the input , it is called positive feedback. This is also due to the Bakhausen criterion.
@anees-fathima-rc1oFR • Apr 14, 2012
Osillator which means producing output without input, it means we give feedback as input.The input must be positive-directly taken from output,so it is called as positive feedback.If the feedback was negative, it would serve to damp the oscillation and to "kill" the oscillator.
@aarthivg-HH344f • Apr 14, 2012
B. R. Sainyes, a positive feedback is required. As oscillator does not use any input ideally so it uses positive feedback. When output is applied to the input , it is called positive feedback. This is also due to the Bakhausen criterion.
thanks @ #-Link-Snipped-#.
what is Bakhausen criterion -
@silverscorpion-iJKtdQ • Apr 15, 2012
^^ Barkhausen criterion is a set of conditions under which a linear electronic circuit will oscillate.
<a href="https://en.wikipedia.org/wiki/Barkhausen_stability_criterion" target="_blank" rel="nofollow noopener noreferrer">Barkhausen Stability Criterion</a>
Actally, the 2 condtions are, simply,
1) The loop gain should be 1 and
2) The phase shift around the lop should be zero or a multiple of 2*pi
If these conditions are satisfied, then that circuit will oscillate. -
@nikhil-XXHXbz • Sep 30, 2018
Why - ve feed not produce oscillations
