I would like to know that whether OS X & Windows still runs on PAE Kernels ?0
Administrator • Oct 26, 2013
Thread Moved.Are you sure? This action cannot be undone. -
Member • Oct 26, 2013
That wasn't necessary, as I just wanna know answer in YES or NO.Kaustubh KatdareThread Moved.
Anyways, no problem. You're using Mac, can you tell me whether it uses PAE Kernel underneath or not ?Are you sure? This action cannot be undone. -
Member • Oct 27, 2013
Just because someone is running Mac doesn't mean they will know all kernel stuff 😛
to answer your question, you can discover it by yourself easily. Why PAE is actually required ? Since most of the new Macs are 64 bits, no question of PAE. And older versions OS X supports PAE.
If I am not wrong, even Windows also supports PAE as its necessary in actual.Are you sure? This action cannot be undone. -
How would I discover it by myself, when I don't own a Mac ? 👀
"All New hardware support 64-bit, that doesn't implies that they're running on 64-bit distro". While most of new hardware have 2GB+ RAM & when checking up configuration (from #-Link-Snipped-#) I didn't found any mention of x64/i686 bit of OS X.
So, I was kinda curious to know whether they still use PAE Kernels (as rumored) or not ?
64-bit is the future & using 32-bit OS with 2+ GB RAM on hardware supporting i686 is a buzz-kill.
Anyways, thanks a ton for replying @#-Link-Snipped-#Are you sure? This action cannot be undone. -
Member • Oct 29, 2013
Thats the point, you don't need to own a machine to about OS.
From Wiki : 'Snow Leopard is the last release of Mac OS X to support the 32-bit Intel Core Solo and Intel Core Duo CPUs.'
From Wiki of next OS after Snow Leopard, Lion : 'Platform support : x86-64'
Yup. I should have been clear. When I said new Macs, I meant new distros of Mac OS X.Abhishek Rawal"All New hardware support 64-bit, that doesn't implies that they're running on 64-bit distroAre you sure? This action cannot be undone. -
Member • Oct 31, 2013
Thanks for sharing own good ideas.
<a href="https://www.merriam-webster.com/dictionary/plagiarize" target="_blank" rel="nofollow noopener noreferrer">Plagiarize Definition & Meaning - Merriam-Webster</a>
<a href="https://www.plagiarism-checker.me/" target="_blank" rel="nofollow noopener noreferrer">Plagiarism Checker | Check Plagiarism with Free Plagiarism Detector</a>Are you sure? This action cannot be undone.
