  • Difference Between Spindle, Shaft and Axle?
    ArunSrinivassan
    ArunSrinivassan
    @arunsrinivassan-wr5Fua
    Updated: Feb 3, 2012
    Views: 9.6K
    Sure, let's break down the differences between these three mechanical components: Shaft, Spindle, and Axle.
    A Shaft
    A shaft is a rotating machine element, usually circular in cross section, which is used to transmit power from one place to another.
    Shafts are used in a variety of applications. In a simple machine, it can act as a rod connecting gears or wheels. In more complex systems, it could be part of a motor or turbine, transmitting power from the source to the load.
    Shafts are also common in a variety of machines from cars, where they transmit the power from the engine to the wheels, to electric drills, where they transfer the motor's rotation to the drill bit.
    They can be designed to withstand a combination of radial (bending) loads and axial (thrust) loads, depending on their specific role in the machine.
    A Spindle
    A spindle is a specific type of shaft that typically has a larger diameter and often has features designed for mounting and/or driving parts of a machine.
    The term is most commonly used in the context of machines like lathes or mills, where the spindle is the part of the machine that holds and drives the workpiece or cutting tool.
    Spindles are typically designed to withstand radial loads but can sometimes also be designed to withstand axial loads.
    One common application is in a machine tool, where the spindle holds the tool (like a drill bit or a milling cutter), and the machine provides rotation and feed to perform the operation.
    Spindles can also be found in hard disk drives, where they hold and rotate the magnetic or optical disks.
    An Axle
    An axle is a central shaft for a rotating wheel or gear. In some definitions, axles are not considered to be a part of the drivetrain but instead are the component on which the wheels or other parts rotate.
    However, in other applications, like in most automobiles, the axle is an integral part of the drivetrain and helps transmit power from the engine to the wheels.
    Axles are primarily designed to withstand axial loads as they usually carry the weight of the vehicle and its contents.
    There are different types of axles, including live axles (which rotate with the wheels and transmit power to them), dead axles (which do not rotate and are instead rotated around), and tandem axles (where one axle is mounted in front of or behind another).
    In summary, while all three - shafts, spindles, and axles - are types of rotating machine elements designed to transmit power and/or motion, they each have slightly different uses and roles within a machine.
    A shaft is a general term for a rotating component, a spindle is a type of shaft with specific features for mounting or driving, and an axle is a shaft that is central to a wheel or gear and often carries the load of the vehicle or machine.
  • Keerthivasan Ravisankar
    MemberFeb 3, 2012
    "SPINDLE"
    <a href="https://www.thefreedictionary.com/spindle" target="_blank" rel="nofollow noopener noreferrer">Spindle - definition of spindle by The Free Dictionary</a>
    The Spindle is driving shaft in a lathe in which chuck is connected to it directly.
    Where as
    "SHAFT"
    <a href="https://www.thefreedictionary.com/shaft" target="_blank" rel="nofollow noopener noreferrer">Shaft - definition of shaft by The Free Dictionary</a>
    A shaft is a mechanical component for transmitting torque and rotation, usually used to connect other components of a drive train that cannot be connected directly because of distance from power transmission which is also called as driving shaft.
  • ArunSrinivassan
    MemberFeb 5, 2012
    rkvasan68
    "SPINDLE"
    Where as
    "SHAFT"
    Thank u sir...........Hope to have more doubts that can be clarified from u as well as frm other seniors
    MemberFeb 6, 2012
    You are welcome
  • zaveri
    MemberMar 23, 2012
    shaft : transmits torque and supports the driven member
    spindle : transmits torque only, but does not support any driven member
    similarly there is another type of shaft which is designed only as a load carrying member and not torque transmission. that is the axle shaft in automobiles
  • Siddhant Mukherjee
    MemberMar 24, 2012
    spindle is a wider term than that of shaft . It consists of the rotating axis of a machine tool including the shaft, bearings and parts attached to it such as centers in case of lathe. But the shaft is the main component which defines the spindle.
    so we can say that every spindle is a shaft but every shaft is not a spindle.
