@civilprincess-308hDv • Feb 7, 2010
Re: slabs
One way slabs are designed to transfer their loads to only two opposite support walls. Generally for spans up to 3.60 meters and with length/breadth ratio is greater than 0.60 one way slabs can be provided.the reinforcement will be along the longer direction.
Two way slabs are designed to transfer their loads to all the four support walls. Generally for spans greater than 3.60 meters and with length/breadth ratio is less than 0.60 two way slabs can be provided.the reinforcements will be placed along the length and the breadth i.e. the reinforcements will be perpendicular to one another.
A one way slab, have it structural strength in shortest direction.
A two way slab, have it structural strength in in two direction. -
@guttu-Udy454 • Feb 9, 2010
Re: slabs
One way slabs bend in one direction and load is distributed in one direction only. They behave like a beam. slabs with length/breadth ratio above 2 are considered as one way slabs.
Two way slabs are those where length/breadth ratio is below 2. The load is distributed in all four sides. Deflection and bending is reduced to a great extent compared to one way slab.
In both case main reinforcement is provided along long span. -
@jagadeshkannan-2fBXw4 • Feb 25, 2010
Re: slabs
GuttuOne way slabs bend in one direction and load is distributed in one direction only. They behave like a beam. slabs with length/breadth ratio above 2 are considered as one way slabs.
In both case main reinforcement is provided along long span.Hi Mr.#-Link-Snipped-#
Your explanation about one way & two way slabs was good, but you have mentioned "In both case main reinforcement is provided along long span" thats wrong. for one way slab the main reinforcement should be along the shorter span. -
@undo-cQ0l89 • Mar 26, 2010
Re: Difference between one way and two way slab in terms of their structural behaviou
for one way slab. the bending of slab is along the short span. technically.. we avoid doing bottom rebar splice at mid span.
but figuratively with a ruler, the bending is along the longest span. im quite confuse as my lecturer love to make bending examples with a ruler. -
@de-divine-4Fn6XP • Jul 11, 2014
For one way slab, the bending of slab is along the shorter span. Then where does two way bending takes place
@thebigk • Jul 10, 2017
Learn about One way & two way slab and how to identify whether it is a one way or two way slab? here <a href="https://civilread.com/differences-one-way-slab-two-way-slab/" target="_blank" rel="nofollow noopener noreferrer">Difference between One Way Slab and Two Way Slab</a>
