Difference | 2-Stroke Engine, 4-Stroke Engine
Listed below is the difference between 2-Stroke and 4-stroke engines:
In case of two stroke engine, rotation of crank shaft will be power stroke for every one rotation. During compression stroke, fuel will flow towards the crank case(suction) and during power stroke, exhaust will emit the burnt fuel through the transfer ports.
While in case of four stroke engine, rotation of crank shaft will be power stroke for every two rotation. Moreover, suction compression power and exhaust strokes are separate as there will be inlet and exhaust valves.
Image via: 4Stroke Machines
.jpg)
