Detect if electronic coil is damaged?
I took a picture of the three coils. One of them is discolored (slightly darker than the other two). Could you please tell me if you notice if this could mean the coil is damaged.
@skipper-wJtaxo • Jun 11, 2009
@bob2300nx-Ec9D7j • Jun 11, 2009
I can not find really any info on this tv. It is made by electrograph which went out of business 3 weeks ago. Tv is about 4 years old so its not worth taking to a tv man.skipperIt's just a little tricky to get more than a "maybe it's that thing" impression with a picture or a casual look.
My advice is: take it to a shop that has the equipment, or get some yourself. I would also recommend the manual specifically for the TV model you want to look at fixing, a book on Electronics will be useful but you want to do as little debugging of the circuit design as possible - it saves a lot of time for starters. You don't have to be an expert etc.
What your picture appears to show are choke coils across, maybe, the power rails to smooth the AC. If one of the rails is dead or overvoltage I would not recommend powering it up, you can still investigate the circuit when it's not live.
From experience, the top coil of the three does look discolored. Can you notice a burnt smell when you get close to it? Does it or the other coils warm up? Usually the enamel cooks or goes dark when you cook a coil. If you get an internal short the coil is DOA.
Yes I have. Surprisingly all the boards inside that have a manufacture listed are samsung, which makes finding it much easier. This board on ebay has the same model number as the board in my tv. There are slight differences like a few extra heatsinks. But I suspect is that electrograph took the basic board from samsung and added a few extra touches.skipperAn experienced engineer might mention that replacing a blown fuse is often the shortest path to another blown fuse. You have to uncover why the coil looks discolored, why the fuse blew or you'll be replacing fuses.
Have you looked at replacing the PS or not much hope of finding one?
