Detailed engineering on Engine!
viky1147
@viky1147-Ru5Vmg โ€ข Oct 26, 2024
Hi Everyone,
i know how an engine works. What i want to know is what are the materials used for engineering a engine. Like the material of cylinder block, crank case, cylinder, valves, piston, cam shaft etc. I want the reason behind the selection of the materials. I need it briefly ๐Ÿ˜€
  • Al-Otaiby
    @al-otaiby-IfzGz4 • Feb 6, 2012
    I have everything at home, once I get back I'll check my university books and get back to you ๐Ÿ˜€
  • viky1147
    @viky1147-Ru5Vmg • Feb 7, 2012
    Awaiting
    #-Link-Snipped-# ๐Ÿ‘
    @ramani-VR4O43 • Feb 7, 2012
    <a href="https://en.wikipedia.org/wiki/Cylinder_block" target="_blank" rel="nofollow noopener noreferrer">Cylinder Block</a>
    <a href="https://books.google.co.in/books?id=mX1-OJBQ6ngC&pg=PA713&lpg=PA713&dq=ic+engine+materials+of+construction&source=bl&ots=ilktWw9wxW&sig=tenPU_8NTnyg5L3T1T_J6r5wz3M&hl=en&sa=X&ei=dBgxT7K_GpHxrQfH8I2tBA&ved=0CGIQ6AEwBjgU#v=onepage&q&f=false" target="_blank" rel="nofollow noopener noreferrer">Internal Combustion Engine in Theory and Practice, second edition, revised ... - Charles Fayette Taylor - Google Books</a>
  • viky1147
    Thanks sir! Will go through it
  • mechky
    @mechky-jbqpJD • Feb 7, 2012
    cylinder block - grey cast iron/cast iron alloyed with nickel & chromium/aluminium alloy
    crankcase - alloy cast iron/plastics
    cylinder - cast iron/aluminium alloyed with silicon
    valves - chromium-silicon steel(silchrome & volmax) also known as valve steel
    piston - alloy cast iron/aluminium alloy
    camshaft - alloy cast iron
  • Al-Otaiby
    @al-otaiby-IfzGz4 • Feb 7, 2012
    Here you go buddy ๐Ÿ˜€
    -Cylinder block in old engines and diesel engines are made of grey cast iron (it can take high compression)
    -Cylinder block in air cooled engines and new engines are made of Aluminium alloy (It gains and looses heat rabidly)
    -Oil pan is made of steel plate (it looses heat fast and can resist hits)
    -Pistons are made of Aluminuim alloy in normal cars and from gery cast iron mixed with aluminuim alloy in new and sport cars (better heat treatment and can take compressions)
    -oil rings are made of steel chips for flexibility
    -compression rings are made of steel
    -Piston arms are made of tempered and normalised steel for high bending torque.
    -Crankshaft is made of steel or cast iron with spherical graphite requirements and to achieve high resistance to stresses often used Hardening Alloy Steel.
    -Flywheel Made of steel cast-iron mixture
    If you need anything else please don't hesitate to contact me.
  • viky1147
    Thanks a lot both of you ๐Ÿ˜€ Hats off!
  • CE Designer
    @ce-designer-BWq0yl • Feb 10, 2012
    Cast Iron is formed from Iron-carbon alloys having a very high percentage of carbon.
    In gray cast iron the excess carbon forms graphite flakes in the microstructure whilst in white cast iron the excess carbon forms cementite which makes white cast iron extremely hard and brittle, more so than gray.
  • zaveri
    @zaveri-5TD6Sk • Apr 2, 2012
    gray cast iron has granules of graphite in it which constitutes the pearlite
  • zaveri
    @zaveri-5TD6Sk • May 26, 2012
    viky1147al-otaiby
    Wat about Valves, Gears, Chasis?
    And wats the difference between Gray cast iron and cast iron?
    chassis is not part of the engine.
    but anyways, we use steel as its material
  • viky1147
    @viky1147-Ru5Vmg • Apr 30, 2023
    al-otaiby
