  • DESIGN AND DEVLOPEMENT OF SPECIAL TOOL FOR PRODICING SQUARE HOLE
    kamblerohit987@gmail.con
    @kamblerohit987-at-gmailcon-vn9BnN
    Updated: Oct 26, 2024
    Views: 1.1K
    Project Abstract / Summary :
    Abstract
    The main aim of this project is to produce square hole by converting a circular motion into square by using a mechanical linkages such as flexible coupling, guiding mechanism and Reuleaux triangle. Flexible coupling allows Reuleaux triangle to rotate in eccentric manner to produce square hole. Reuleaux triangle restricted to stay inside the square guide, and that will create a perfectly square locus and this can be turned into working square hole drill. In actual practice driving end is connected to the vertical drilling machine and driven end is assembled with special drill bit.
    Why did you choose to work on this project topic : THE MAIN ADVANTAGE OF THIS PROJECT IS TO MAKE SQUARE HOLE BY USING A VERTICAL DRILLING MACHINE, WITH SIMPLE ARRANGEMENT; AND REDUCE THE TIME AND MONEY THAT REQUIRE TO PRODUCE SQUARE HOLE ON C.N.C. OR BY USING L.B.M(LASER BEAM MACHINE). THEREFORE IT VERY CHEAP AND NO SKILLED WORKER IS REQUIRED AS COMPARED TO C.N.C. OR L.B.M.
    Project Highlights : THE IDEA BEHIND THIS PROJECT IS VERY INNOVATIVE AND NEW;NO ONE DID THIS PROJECT IN INDIA BEFORE US, AND ALSO NO ONE HAVING THAT MUCH KNOWLEDGE ABOUT THIS SQUARE HOLE DRILLING PROCESS,THEREFORE IF WE WINS THIS CONTEST THEN IT'S VERY HELPFUL TO SHARE OUR KNOWLEDGE TO OTHER STUDENT AND HELPFUL TO INCREASE THE GROWTH OF OUR COUNTRY.
    Institute/College Name: VIDYAVARDHINI COLLEGE OF ENGINEERING AND TECHNOLOGY . VASAI ROAD
    City: VASAI ROAD WEST
    State: MAHARASHATRA
