Current flowing through railway track
yogi.bharadwaj
@yogibharadwaj-l2QJTU โ€ข Oct 27, 2024
Hello friends every body knows that current flows across the metals and the railway track and the rail compartments all are metal . So friends my question os that of we touch a high voltage wire to the railway track then how far is the current flows across the rail track and what happens if a current passes near by of it. Because the high voltage wore has very high voltage so we cannot consider that the voltage will dies out after some distance because the voltage is very high.since the train boggie is also a metallic so os the passengers got a shock if high voltage wire touches railway track.
So friends pls reply with appropriate reason.
  • narayana murthy
    @narayana-z4W16q • Oct 9, 2013
    i cant understand your question completely but as i understood my answer is no because if that wire touches the track automatically it should be open so no current will be transfered anyhow railway high voltage lines are not so neglected. They will take precautions
  • lal
    lal
    @lal-R60Xjx • Oct 9, 2013
    Railway tracks are earthed at frequent intervals. So it doesn't matter if any kind of loose wire falls over it. In railway traction, circuit is completed using the earthed railway track. But there is no risk of electrick shock on the track since all the current will be flowing to earth.
  • Saandeep Sreerambatla
    @saandeep-sreerambatla-hWHU1M • Oct 10, 2013
    If you see any railway track, after few meters a iron rod is connected to the track lines and to the ground to eliminate the current produced in the tracks.
    So in your question , if the high tension wire touches the track then all the current will flow to the earth.
    As far as i know , Current always chooses the low resistance path, in this case the rod connected to the track will have low resistance compared to the train.
  • yogi.bharadwaj
    @yogibharadwaj-l2QJTU • Oct 10, 2013
    narayana murthyi cant understand your question completely but as i understood my answer is no because if that wire touches the track automatically it should be open so no current will be transfered anyhow railway high voltage lines are not so neglected. They will take precautions
    Friend i am mot pointing the fingure to the high voltage security i am just wamt to know how far its effect can be felt if we touch a high voltage line to the railway track i specify railway track because ot only which ia condictor with very large length so reply for it.
  • yogi.bharadwaj
    Saandeep SreerambatlaIf you see any railway track, after few meters a iron rod is connected to the track lines and to the ground to eliminate the current produced in the tracks.
    U r right but i just want to know after how far traveling the losses will dies the high voltage flowing through rail track.
  • lal
    lal
    @lal-R60Xjx • Oct 10, 2013
    I think you have misunderstood railway tracks as the carriers of current, which is not actually the case. You can see overhead lines which carry current to power the locomotive over the tracks.
    Even if a high volateg wire touches the track, no one will be electrocuted. Current will simply be bypassed to ground.
