@bharathpb-FtEhYi • Aug 16, 2010
Can u provide the exact model of your wireless router of net gear.
@special-bJB6Ij • Aug 16, 2010
WGR614 V9 this is the exact model name of neatgear wireless router which i am using
not sure of the configuration part....sorry for tht
but try the default username as 'admin' and password as 'password'
further you can explore -
i could not do this thats why i asked here
@manish-r2Hoep • Aug 16, 2010
Have you tried google?
@durga-TpX3gO • Aug 16, 2010
hehe
i did write up a step by step configuration . i have the same router as yours and dont have the router config CD
see this link :-
<a href="https://everything-on-mind.blogspot.com/2009/09/i-did-little-trouble-shoot-on-my.html" target="_blank" rel="nofollow noopener noreferrer">everything on mind</a> -
@special-bJB6Ij • Aug 17, 2010
@durga
i am not able to login to the page with defaults provided -
@durga-TpX3gO • Aug 17, 2010
do you see the reset button? It I believe, is somewhere near the porous steel cover , next to the LAN ports Its a very tiny black in colour button. You can always reset the router and start afresh.
All the routers use the default logins and unless and until someone has changed the details.
if possible please post the screen shots for better trouble shooting -
@durga-TpX3gO • Aug 18, 2010
hi
did you try resetting and then try loggin in? how did it go? -
@special-bJB6Ij • Aug 21, 2010
@durga
Can you tell me how to block websites??? using this router? i tried using keywords but after using a proxy server it does not work.......... -
@anandkumarjha-jzdDMA • Aug 21, 2010
For configuring your routers it is necessary to know your type of router because as far as i know each router has different configurations ...
<a href="https://www.tomax7.com/mcse/cisco_routerconfig.htm" target="_blank" rel="nofollow noopener noreferrer">Cisco Router Configuration Commands</a> this is the link where from you can be aquented with much more knowledge regarding router configuration -
@durga-TpX3gO • Aug 21, 2010
Special@durga
Can you tell me how to block websites??? using this router? i tried using keywords but after using a proxy server it does not work..........can you explain a little more?
@ anand
The commands are exclusive to Cisco routers, special is having issues with netgear routers -
anandkumarjhaFor configuring your routers it is necessary to know your type of router because as far as i know each router has different configurations ...
<a href="https://www.tomax7.com/mcse/cisco_routerconfig.htm" target="_blank" rel="nofollow noopener noreferrer">Cisco Router Configuration Commands</a> this is the link where from you can be aquented with much more knowledge regarding router configurationthese commands only works for cisco routers, because they have the own operating system and they support both cli(command line interface) mode and gui also ,
where as my router is concerned i already specified that it is of netgear not of cisco which only supports gui mode -
@durga
what should i explain???
can u just help me out in blocking websites using netgear router at its configuration mode........ -
do i smell frustation
here if you have already tried entering the iste details in below page please put up the error message
![[โIMG]](proxy.php?image=http%3A%2F%2Fimg44.imageshack.us%2Fimg44%2F7159%2Fnetgearblocking.png&hash=b971cc3fbb8fd54382cad510a4644b02)
P.S: i screwed up my house wifi today and it took me whole 3 hrs to fix it . Forget my housemate's frustration. -
@ durga
no no please dont take it the otherway....
the above you have show is done by me but it didnot work, when i used a proxy server like ultra surf everything was unblocked -
hmm, proxies are meant to take you around the settings. Did you try content filtering softwares?
@special-bJB6Ij • Aug 22, 2010
@ durga
can you suggest me the content filtering software for my whole network.......
