  • imnitsy
    @imnitsy-VRNV82 Jan 30, 2010
    it nature is AC!!
    adding a dc in ac signal will increase the magnitude by the dc voltage!!😁
    correct me if i am wrong!!
  • imnitsy
    also the magnitude of the resultant voltage must be sqrt(100+25)!!!!
  • ankita15
    @ankita15-7zSWG6 Jan 31, 2010
    it will be ac,,,,,,,,as sin function is there,,,,,,,,
    correct ,,,,if it is wrong ans.
  • nitin_sharma
    @nitin-sharma-W1sln9 Feb 1, 2010
    It will be an ac signal which will fluctuate about the 10V DC level instead of ground level.
  • sanks85
    @sanks85-20puY7 Feb 1, 2010
    if we draw the graph of both the DC as well as AC function then the resultant will be in AC form with the magnitude around 10v so it will be purely an AC signal...
  • amanoverworked
    @amanoverworked-ISRQkL Feb 3, 2010
    but according to the definition of alternating current its direction changes , but here it is fixed.
  • Rifaa
    @rifaa-NaWZZ4 Feb 3, 2010
    With 10VDC and 5VAC together means AV is super imposed on DC.
    Resultant will be a DC Voltage with an AC component ( like a ripple in DC).
    Graph will look like an AC sine wave via a scope provided the DC function is enabled, with a reference at 10V instead of 0V as a pure sine wave would look like.
    Rifaa
  • 360degrees
    @360degrees-8U1wAp Feb 8, 2010
    I think its dc in nature.Not a perfect DC but a pulsating one.I think so because when (wt)=0,its value =10;wt=90,its value=15,wt=180 it again becomes 10 and wt=270 it is 5.
    So it varies from +5 to +15V.
    So it is a DC.
  • 360degrees
    This is basically the output of a clamper circuit.It is used in DC insertion in Television etc..
  • shahrul
    @shahrul-Ex12xz Feb 11, 2010
    RifaaWith 10VDC and 5VAC together means AV is super imposed on DC.
    Rifaa
    Agree, the DC voltage greater than the AC amplitude. So, the adding result is all the value will be positif. So, no alternating voltage. It's DC signal.
  • roxy_1001
    @roxy-1001-6yiSLX Feb 13, 2010
    i hope this diagram will help you to clear you doubt ...
    [​IMG]
    things you can see...
    1) It's normal sinewave shifted 10 v above the 0v level...
    2) It will have no -ve cycles..
    3) It will fluctauate above and below 10v refernce level...
    4) If you add -10v instead of adding +10v the whole graph will be shifted below the 0v.
    5) This kind of waveforms are called as Fluctuating DC's ..not AC...😁
