@maria-flor-8cAkif • Mar 28, 2011
1. Underground plumbing- The plumbing drain and waste lines that are installed beneath a basement floor.
2. Water tap- The connection point where the home water line connects to the main municipal water system.
3. Mullion- A vertical divider in the frame between windows, doors, or other openings.
@civilprincess-308hDv • Mar 28, 2011
Tensegrity, tensional integrity or floating compression, is a structural principle based on the use of isolated components in compression inside a net of continuous tension, in such a way that the compressed members (usually bars or struts) do not touch each other and the prestressed tensioned members (usually cables or tendons) delineate the system spatially. this concept is used in many structures like tents, fabric domes, towers.
the following picture shows a tensegrity tower from the bottom.
lintel:
a beam that the takes the load of the construction materials above the door or window so that the frames and windows don't have to bear the stress due to the dead weight. -
Eaves- The horizontal exterior roof overhang.
![[โIMG]](proxy.php?image=http%3A%2F%2Fwww.builderbill-diy-help.com%2Fimage-files%2Feaves-framing-l.gif&hash=7c166eb96c92b79300f0577bfe5230c4)
Elevation sheet- The page on the blue prints that depicts the house or room as if a vertical plane were passed through the structure.
Dampproofing- The black, tar like waterproofing material applied to the exterior of a foundation wall.
![[โIMG]](proxy.php?image=http%3A%2F%2Fwww.3d-ess.com%2Fimages1%2Fdamp%2520proofing.jpg&hash=38445afc066f8cf329cff9e1e070f4e6)
coping : capping or covering of a wall
green building:
a building that operates in such a manner that it provides the following advantages to the inhabitants.
1. healthier atmosphere (i.e. does not release intoxicating gases like CO2)
2. less or zero energy demand.
3. efficient waste disposal -
Tail beam- A relatively short beam or joist supported in a wall on one end and by a header at the other.
![[โIMG]](proxy.php?image=http%3A%2F%2Fchestofbooks.com%2Farchitecture%2FConstruction-Superintendence%2Fimages%2F48-Framing-Around-Stair-Wells-Chimneys-Etc-20021.png&hash=f150bfc6c238b9da8d88b9b00cd58bd1)
dove tail joint: a type of joint used in carpentry
![[โIMG]](proxy.php?image=http%3A%2F%2Fwww.experthow.com%2Fwp-content%2Fuploads%2F2010%2F12%2Fdovetail-joint.gif&hash=013879a8d9ba3b9760a7c97c06fa04ed)
Tread- The walking surface board in a stairway on which the foot is placed.
Trimmer- The vertical stud that supports a header at a door, window, or other opening.
![[โIMG]](proxy.php?image=http%3A%2F%2Fwww.diy-resources.com%2Fimages%2Forth-brt-85-0.jpg&hash=6a2896e792e8bf46118629a50df956bb)
maria florTread- The walking surface board in a stairway on which the foot is placed.
rise: the difference in level between two consecutive steps.
always the tread has to greater than rise. -
@maria-flor-8cAkif • Mar 29, 2011
Jamb- The side and head lining of a doorway, window, or other opening. Includes studs as well as the frame and trim.
Hurricane clip- Metal straps that are nailed and secure the roof rafters and trusses to the top horizontal wall plate. Sometimes called a Teco clip.
![[โIMG]](proxy.php?image=http%3A%2F%2Fwww.theinfomine.com%2Fwp-content%2Fuploads%2F2010%2F10%2Fhurricane-clip.jpg&hash=a86d163e643cd636bfb71ee8e930aefa)
Waferboard - A manufactured wood panel made out of 1โณ- 2โณ wood chips and glue. Often used as a substitute for plywood in the exterior wall and roof sheathing.
![[โIMG]](proxy.php?image=http%3A%2F%2Fkrumber.com%2Fosb.jpg&hash=75252b84e6e9b3aef74b450c6af99b58)
Top chord- The upper or top member of a truss.
Bottom chord โ The lower or bottom horizontal member of a truss.
![[โIMG]](proxy.php?image=http%3A%2F%2Fwww.axiominspection.com%2Fimages%2Fg_chords.jpg&hash=e3a5584d545de5e6134c5a7dce7a87a5)
@maria-flor-8cAkif • Mar 30, 2011
Landing- a platform between flights of stairs or at the termination of a flight of stairs. It is often used when stairs change direction. Normally no less than 3 ft. X 3 ft. square.
![[โIMG]](proxy.php?image=http%3A%2F%2Fwww.make-my-own-house.com%2Fimages%2Flanding.jpg&hash=6e1652318b2b2e8a30fa902500be976d)
Inside corner- The point at which two walls form an internal angle, as in the corner of a room.
Water closet- Another name for toilet.
Door operator- it is an automatic garage door opener.
Chalk line- A line made by snapping a taut string or cord dusted with chalk. Used for alignment purposes.
Cooling load- The amount of cooling required to keep a building at a specified temperature during the summer, usually 78ยฐ F, regardless of outside temperature.
Bearing wall- A wall that supports any vertical load in addition to its own weight.
Bay window- is any window space projecting outward from the walls of a building, either square or polygonal in plan.
Bedrock- A subsurface layer of earth that is suitable to support a structure.
Column- A vertical structural compression member which supports loads.
DWV (drain-waste-vent)- The section of a plumbing system that carries water and sewer gases out of a home.
Lattice- An open framework of criss-crossed wood or metal strips that form regular, patterned spaces.
Outside corner- The point at which two walls form an external angle, one you usually can walk around.
Reducer- A fitting with different size openings at either end and used to go from a larger to a smaller pipe.
Seasoning- Drying and removing moisture from green wood in order to improve its usability.
@maria-flor-8cAkif • Mar 31, 2011
Bridging-Small wood or metal members inserted in a diagonal position between the floor joists. They brace the joists and spread the loads.
Miter joint-a joint formed by fitting together two panels or pieces of wood that have been cut at the same angle.
Patio-a recreational area constructed on the ground.
Window frame- The stationary part of a window unit; window sash fits into the window frame.
Glazing- The process of installing glass, which commonly is secured with glazierโs points and glazing compound
Flatwork- Common word for concrete floors, driveways, basements, and sidewalks.
Downspout- A pipe, usually of metal, for carrying rainwater down from the roofโs horizontal gutters.
By pass doors- Doors that slide by each other and commonly used as closet doors.
@maria-flor-8cAkif • Apr 8, 2011
Wall out- When a painter spray paints the interior of a home.
Warping- Any distortion in a material.
Vent- A pipe or duct which allows the flow of air and gasses to the outside.
Expansive soils- Earth that swells and contracts depending on the amount of water that is present.
Balusters- Vertical members in a railing used between a top rail and bottom rail or the stair treads. Sometimes referred to as โpicketsโ or โspindlesโ.
Attic Ventilators- In houses, screened openings provided to ventilate an attic space.
PVC-Poly Vinyl Chloride, a type of plastic used for irrigation pipe and fittings.
