@harshad-ukH5ww • Mar 30, 2011
N.Gowtham RajHow to check whether a stepper motor is working or not?? My stepper motor has 6 wires for input to be integrated with circuit.....
Please help me out .... its urgent....It means you want to test that the Stepper motor is OK or not?
@ngowtham-raj-PZyKS4 • Mar 30, 2011
Yeah... Exactly...
N.Gowtham RajYeah... Exactly...
well not sure but i think you can check the windings of the Motor it should be show continuity or some resistance.
@aalandkar-R9Nf1k • Mar 30, 2011
check the resistance of the windings with respect to the common winding. You will get what you are searching for.
@shubhankar-CeulhT • Apr 1, 2011
it cannot be told without looking at the motor. each piece is differently designed to suite the purpose. you must be having a manual or something?
@gowtham-jgr-EtAaav • Feb 3, 2012
Check the connection with Multimeter for continuity and check the resistance across the two wires A+,A- and B+,B-,/.... then connect
I have 6.6 ohm for 4.2 kgcm Torque ๐ -
@raghunathreddy36-FhZFqH • Feb 3, 2012
Please help me out .... its urgent....giving digital pulses to stepper motor. u r stepper motor have number of poles.
@4-tech-eIRteZ • Feb 3, 2012
i think trying to drive it using a stepper motor driving circuit would clear d doubt . . .
@kenjackson-mBf7HF • Feb 4, 2012
Do you have a data sheet for it?
If not, what markings are on it?
What company manufactured it?
What model and/or part number are stamped on it?
