CE Board Exam- Design and Construction Review Problems
Concrete beam 8meters long and spaced 4m center-to-center are used to support a concrete slab 115 mm thick. The beams have effective depth of 650 mm measured from the slab surface, bw=300mm, and are reinforced for tension only with six 28-mm-diameter bars. The beams are to be analyzed as T-beams. Steel yield strength fy=350MPa and concrete strength fc=21MPa.
1. Which of the following most nearly give the width of slab effective as T-beam, in millimeters?
A. 2000
B. 2140
C. 4000
D. 3250
2. Which of the following most nearly give the depth of compression block in millimeters?
A. 36.2
B. 45.2
C. 56.3
D. 62.4
3. Which of the following most nearly give the nominal moment capacity of the beam in KiloNewton-Meter.
A. 563
B. 784
C. 952
D. 817
Bill of quantity is to be prepared for guardhouse 3.6 m in height with one door opening only and a height of 2.1m as shown. Assume density of steel equal to 7860 kg/m3. CHB is 200 mm x 400 mm and 150 mm thick.
![[IMG]](proxy.php?image=http%3A%2F%2Fce-review.com%2Fwp-content%2Fuploads%2F2010%2F06%2FStructural-CE-Board-Exam-Nov.-2008-Figure-4.png&hash=6795ff3aec15eca9c47df6964c79fb8b)
1. Which of the following most nearly gives the total length of 12mm bars in meters:
A. 72
B. 65
C. 86
D. 58
2. Which of the following most nearly gives the weight of 12mm bars in Kilogram per meters:
A. 0.89
B. 0.75
C. 0.93
D. 0.63
3. Which of the following most nearly gives the total weight of 12mm bars in Kilograms:
A. 44
B. 58
C. 77
D. 64
A group of friction piles is shown in figure. The total load on the pile less the soil displaced by the footing is 1800kN. The clay is 16m thick. Ground water table is located 2m below the clay surface.
![[IMG]](proxy.php?image=http%3A%2F%2Fce-review.com%2Fwp-content%2Fuploads%2F2010%2F06%2FHydraulics-CE-Board-Exam-Nov.-2008-Figure-9.png&hash=1c04906b316d46bdf6b97ed01d40566a)
1. Compute for the effective pressure the mid height of the consolidating clay layer, in kPa.
A. 186.4
B. 174.8
C. 147.6
D. 163.5
2. Compute for the compression index of the clay.
A. 0.297
B. 0.245
C. 0.325
D. 0.288
3. What is the approximate settlement of the foundation?
A. 150 mm
B. 168 mm
C. 214 mm
D. 198 mm
A. 2000
B. 2140
C. 4000
D. 3250
A. 36.2
B. 45.2
C. 56.3
D. 62.4
A. 563
B. 784
C. 952
D. 817
A. 72
B. 65
C. 86
D. 58
A. 0.89
B. 0.75
C. 0.93
D. 0.63
A. 44
B. 58
C. 77
D. 64
A. 186.4
B. 174.8
C. 147.6
D. 163.5
A. 0.297
B. 0.245
C. 0.325
D. 0.288
A. 150 mm
B. 168 mm
C. 214 mm
D. 198 mm
