Capacitor as loading device
What exactly is the loading effect of capacitor? I found this as one of the main applications of the capacitor in electronic circuits.
The book pointed that the capacitor in the input of a transistor acts as a loading capacitor. How and what it loads and where does it load?
Some insight in any form will be really helpful.
  • pinank
    @pinank-6TUo5O Aug 22, 2013
    As per my knowledge capacitors are used as fillers in electronics!
  • Jeffrey Arulraj
    @jeffrey-xA7lUP Aug 22, 2013
    You mean filters right Yeah I agree to filters
    But I found in a book that the capacitors are used to load in an electronic circuit
    I figured that it loads the input AC signal without any DC interference to the input of the Transistor or FET I am still not clear about this though
  • pinank
    Ahh...no...they are primarily used as filters...either to filter out harmonics or as a lpf, hpf etc etc
  • Jeffrey Arulraj
    pinankAhh...no...they are primarily used as filters...either to filter out harmonics or as a lpf, hpf etc etc
    Yup true But David Bell states That capacitors serve 3 purpose
    • Filters
    • DC blockers
    • Loading circuits
    That gets me going over the heel to find what exactly is loading
  • ABCD ABCD
    @abcd-2NEyMb Aug 22, 2013
    loading circuits? ... doesn't that mean it works as a load?
  • Jeffrey Arulraj
    Well I am not sure load is connected in the input section of the circuit right
    mreccentricloading circuits? ... doesn't that mean it works as a load?
    Loading occurs in the input and not in the output side where we use a loading resistance to increase or decrease the output impedance
  • pugazh anand
    @pugazh-anand-GgZB1c Aug 23, 2013
    Is ter any similarities btwn impedance matching & cap loading?
    @ramani-VR4O43 Aug 24, 2013
    ConquerorWell I am not sure load is connected in the input section of the circuit right
    A fully discharged capacitor can act as a DC load till it is fully charged. It has effectively zero resistance to start with. After this its equivalent resistance increases and it just blocks DC. It will let through AC signals.
    I am not sure if this behaviour is what is referred to by David Bell.
  • pinank
    @pinank-6TUo5O Aug 24, 2013
    A.V.RamaniA fully discharged capacitor can act as a DC load till it is fully charged. It has effectively zero resistance to start with. After this its equivalent resistance increases and it just blocks DC. It will let through AC signals.
    Sir but won't that be for a very small fraction of time..as the capacitor will charge up almost instantaneously(at least theoretically)
    pinankSir but won't that be for a very small fraction of time..as the capacitor will charge up almost instantaneously(at least theoretically)
    You are right. Often that is all that is required.
  • ABCD ABCD
    @abcd-2NEyMb Aug 26, 2013
    i counter this... It's not always a fraction of time. The rate of charging can be altered. So, i guess, it can be made so that the capacitor may act as a DC load for long time (in other words infinite time).
    @ramani-VR4O43 Aug 26, 2013
    mreccentrici counter this... It's not always a fraction of time. The rate of charging can be altered. So, i guess, it can be made so that the capacitor may act as a DC load for long time (in other words infinite time).
    Every capacitor has an RC value, which is a function for charging time. The R restricts the charging current. the total charge that can be held is decided by the C value. infinite time is possible only with infinite R. That is open circuit. Otherwise it is finite.
  • pinank
    @pinank-6TUo5O Aug 26, 2013
    The capacitor will always tend to reach its steady state value ie once it is fully charged it acts as a open switch and the rate can be altered by changing the time constant value.. But at say time equals infinity it will eventually act as a open switch
  • Ahsanul haque
    @ahsanul-haque-2o7iUb Sep 3, 2013
  • tanmoya
    @tanmoya-4Qa0pr Sep 5, 2013
    capacitors prevents loading effect means...... 'loading effect' means short circuiting of input source. if the circuit has low input impedence then the circuit will draw maximum current and this will result on short circuiting of input source.
  • Jeffrey Arulraj
    @jeffrey-xA7lUP Sep 6, 2013
    tanmoyacapacitors prevents loading effect means...... 'loading effect' means short circuiting of input source. if the circuit has low input impedence then the circuit will draw maximum current and this will result on short circuiting of input source.
    Can you be more specific Cos How is the capacitor going to affect the impedance of the circuit
    Do you mean the DC impedance or the AC impedance
  • tanmoya
    @tanmoya-4Qa0pr Sep 6, 2013
    capacitor is obvious to be AC impedence.... it is used for coupling of input too...
  • kumarrakeshit
    @kumarrakeshit-AEuTYt Apr 29, 2014
    In my point of view capacitor just like to holding electricity of certain time period. And we can replace battery with capacitor.
  • Jeffrey Arulraj
    @jeffrey-xA7lUP May 1, 2014
    But how does it affect the input of my circuit.
    What type of load does it provide to the input ciruit to which the capacitor is connected
    @ramani-VR4O43 May 1, 2014
    Is this of any use?
  • vamsi kancharla
    @vamsi-kancharla-kL9oxU May 1, 2014
    Jeffrey SamuelWhat exactly is the loading effect of capacitor? I found this as one of the main applications of the capacitor in electronic circuits.
    capacitors are also used for timming purpose in an electronic ckts
  • kumarrakeshit
    @kumarrakeshit-AEuTYt May 1, 2014
    Suppose if you are converting the ac to dc current then you must use the capacitor. then you can get desire output.
    I will search your question answer please give me some time. friend.
  • pinank
    @pinank-6TUo5O Jun 12, 2014
    can this be the counter argument. Taking a simple circuit A BJt and AC signal is applied to its base. Now if there is no AC impedance, (CAPACITOR) the source will get Short circuited. And lead to damage of Bjt. Hence the capacitor would work as a loading device.
  • Jeffrey Arulraj
    @jeffrey-xA7lUP Jun 13, 2014
    Source has some reactive impedance so I am not sure what you are implying
    Can you pls post a little schematic here to explain the scenario little more clearly?
    And Load is generally at the output side and the trans impedance effect of it on the input source is really less in case of Semi conductors right
  • pinank
    @pinank-6TUo5O Jun 13, 2014
    Jeffrey SamuelSource has some reactive impedance so I am not sure what you are implying
    Yeah u r pretty much right..I got it all wrong.. :/
