Can we protect wp-admin directory of WordPress?
I have a WordPress Blog and I was wondering, is there any way to password protect our main admin directory (wp-admin)? This is the main directory and I want to protect it.
Firstly I will pass the credentials for the wp-admin directory and then enter main login details for our WordPress Blog.
    @thebigk Dec 21, 2011
    Pranav KathaleI have a WordPress Blog and I was wondering, is there any way to password protect our main admin directory (wp-admin)? This is the main directory and I want to protect it.
    Yes, you can and you should protect the wp-admin directory. The first method I think it to change the directory name to something else and make adjustments to the config.php.
    Second and simpler method is to protect the directory using password protection. You can check your host control panel for directory protection.
  • Pranav Kathale
    @pranav-xR4cnN Dec 21, 2011
    In the mean time, I have found one Plugin for the same purpose. Plugin provides the facility to create a username-password for securing wp-admin.
    Is it worth using plugin or default CPanel should be used?
    Pranav KathaleIn the mean time, I have found one Plugin for the same purpose. Plugin provides the facility to create a username-password for securing wp-admin.
    Why add plugins? You can simply login to your web host control panel, select the directory you want to password protect and specify a username and password. It's easy. I'm not in favor of using plugins.
  • Pranav Kathale
    I tried protecting directory. I have created username-pass for the directory and enabled protection. But, its not working.
    After enabling this, when we try to access <site_name>/wp-admin/, I am getting "404 error". Why so?
    And when we again remove that directory from the protection, I am getting access to WordPress Login.
    What is happening?
  • jgeorge
    @jgeorge-0LTnP9 Dec 22, 2011
    If you’ve been trying to password protect your wordpress wp-admin directory you’ll probably have encountered an issue when using Cpanel's “Password Protect Directories” tool.
    It’s because when the tool is used it doesn’t set the .htaccess file the right way this causing a “404 error”. The simple fix is to use the “Password Protect Directories” to protect the wp-admin folder then to download the created .htaccess and edit to look like this.
    ErrorDocument 401 default
    AuthType Basic
    AuthName "Name You Gave Your Protected Directory"
    AuthUserFile /home/YOURSERVERDEFAULTFOLDER/.htpasswds/public_html/wp-admin/passwd
    require valid-user
    Then upload it and you’ll have effectively managed to password protect the directory.
  • jgeorge
    this link might be helpful.. #-Link-Snipped-#
  • PraveenKumar Purushothaman
    @praveenkumar-66Ze92 Dec 22, 2011
    You can use the .htaccess files to prevent the entry. Also, you can use the hotlink protection to check out the cookies before entering the wp-admin folder. 😀
    @thebigk Dec 22, 2011
    Praveen-KumarYou can use the .htaccess files to prevent the entry. Also, you can use the hotlink protection to check out the cookies before entering the wp-admin folder. 😀
    Yep, in that case, the password will have to be encrypted.
    The_Big_KYep, in that case, the password will have to be encrypted.
    The general public would not be having the access to see the .htpasswd contents right? Even .htaccess, so is there a problem? 👀
  • Pranav Kathale
    @pranav-xR4cnN Dec 22, 2011
    Quick and completely worth replies. 😀
    Thanks.
