@iastro-ceQ1Kf • Jul 6, 2010
eager2learnπi just got a doubt that can human pulses be used to generate a small amount of electric current atleast? if yes how much it will be....
Yeah.. Indeed buddy!π
Electric current can be generated using human body pulses. I think it will require the same electronic circuitry which will consists of Instrumentation amplifier & All remaining blocks!
No doubt, That current will be in very few micro-amperes. but, only to generate current from human pulses & have some circuitry for that will be not of much use in my opinion because doctors can measure those easily! but, yeah.. Generation is possible!π
eager2learnis there any projects based on this? please help me
Umm.. There are number of projects projects available but, Not exactly on Measuring or Generating Human pulses.. but you can have a look..
Take a look..
π -
@vishnu-priya-L6wLMl • Jul 6, 2010
From human pulse?First time i am confronted with!
@ashishsharma30-bJCohB • Jul 7, 2010
go with piezoelectric crystals.
best suited to convert the mechanical vibrations to electricity. -
@abhinaykumar-DQL43M • Jul 12, 2010
as far as i knw... v can bt it wont be a enough for any use....
@jerryvn01-cxfPwe • Jul 15, 2010
Hi,
Thanks very much for this comment. It help me to think about my ideals.
[FONT="]Apart from that, this link below may be useful: [/FONT] #-Link-Snipped-#
Tks again and pls keep posting. -
@occam-r4fzPC • Jul 17, 2010
As you mention ideals, why not using brainwaves - there might well be some Ohms Law like the higher the ideal the higher the brain current, or voltage?!?
jerryvn01Hi,
@ashishsharma30-bJCohB • Jul 18, 2010
for your kind information, the energy available from that process can be easily used for low power electronics.
@aj-onduty-BvuwMK • Aug 25, 2010
Take human pulses away dear friend. Just view your body movement. You can create a powerhouse from you, atleast for your mobile phone. Do a bit of research on MEMS(Micro electromechanical systems), the piezo electric crystals can utilise each and every vibration you unknowingly produce.
