@nayan-Dhpt4N • Aug 11, 2013
From what I know about solar energy, I can try to put light on that. Solar energy is harvested using solar cells and stored in a battery. That is further converted to AC for use. But I dont think it can be stored in normal batteries.
@cyborg-009-7H92N2 • Aug 11, 2013
Solar energy can be stored in conventional 12/24v lead acid batteries ..
The setup should be Solar panel >Charge controller > battery ..
A diode is usually added at panel to avoid current flowing into it during dark.. -
@ramani-VR4O43 • Aug 11, 2013
The source of electricity is irrelevant to storing it in a rechargeable battery. Appropriate circuitry should be used.
@jeffrey-xA7lUP • Aug 11, 2013
If battery is recharageable then you can charge it with a solar panel
There will not be any problems in it
PS: Use a diode in between the panel and the battery to prevent reverse voltage going from battery to the PV cells -
@ahsanul-haque-2o7iUb • Aug 11, 2013
solar panel using in a tiny calculator to large industries. its vary storage device(battery) size. u must have to use rechargeable battery and need some circuits (Charge controller charging level indicator etc ).
Thanks
