  • Rohan_sK
    @rohan-sk-7ZbDkK • Sep 9, 2009
    What do you mean by one engine. We can have only one piston per cylinder and the engine can be multicylinder. At the most a piston can be double acting, but that too will be in one cylinder only.
    There are V Engines where motion of one piston influences the motion of the other piston which are both situated in seperate cylinders.
  • blacrobous
    @blacrobous-Exhggm • Sep 9, 2009
    if its a double cylinder IC engine it can have two pistons
  • nany_mech
    @nany-mech-RHcVWv • Sep 9, 2009
    there are multi piston engines, V6, V8 , V12, W12 etc; are having multiple pistons, and moment of one piston initiates the moments of other ones.
    Example consider V6 engine, it has 6 pistons and cylinders as well. They are positioned in a V form, with 3 on one side and other 3 on other side.
    This whole unit is an IC engine(of course).
    If we want to have one cylinder and two pistons, as Rohan said it will be a double acting one. That means suction, compression & combustion will take place on both the sides of the piston.
  • Toby
    @toby-rsn4IJ • Sep 10, 2009
    rohan has given a very true answer... gud work man....
    @thebigk • Sep 10, 2009
    Tobyrohan has given a very true answer... gud work man....
    Refrain from using SMS text on CE Forums.
  • gohm
    @gohm-F3UUpP • Sep 11, 2009
    Common twin cylinder designs include: opposed twin, parallel twin & the v twin format.
  • shinde_tukaram
    @shinde-tukaram-r8Oc6l • Sep 12, 2009
    i means .in one cylinder we make partition and use two piston in one anoter side . its possible ? ๐Ÿ˜•
    its give good performance ?
  • raj87verma88
    @raj87verma88-ZpL2Wn • Sep 12, 2009
    shinde_tukarami means .in one cylinder we make partition and use two piston in one anoter side . its possible ? ๐Ÿ˜•
    It won't give good performance, rather you would reduce the performance. Make it heavier, reduce the compression ratio which will reduce the efficiency and reduce the engine discplacement, which will reduce the power generated.
    If you have a new idea that counters these points, then do share it with us.
  • gohm
    @gohm-F3UUpP • Sep 13, 2009
    Plus increased friction and more moving parts for increased failure points. I agree though it is an interesting concept. Any drawings or ideas on how to set it up?
  • 4d1
    4d1
    @4d1-wARNWp • Sep 25, 2009
    [โ€‹IMG]
    this drill is driven by a one-cylinder two-stroke petrol engine. The cylinder has two pistons: a double acting motor/compressor piston and an impacting piston.
    The compressed air is used to return the impact piston and for blowing the hole. The impact piston serves only to transmit the blows to the shank of the drills steel or other tool.
  • 4d1
    4d1
    [โ€‹IMG]
    an opposed piston engine :
    1 intake for the fuel-air mixture
    2 supercharger (here: rotary vane pump; original: Centrix)
    3 airbox to buffer and distribute the mixture
    4 waste valve to limit the pressure level
    5 outlet crank mechanism (runs app. 20ยฐ past the outlet to achieve an asymmetric control diagram)
    6 inlet crank mechanism
    7 cylinder with inlet and outlet slots
    8 exhaust
    9 water cooling jacket
    10 sparkplug
    There existed two versions: one with a displacement of 250 cmยณ, and one with 350 cmยณ displacement. The engine had two cylinders with four pistons, two crankshafts and a supercharger. The crankshafts were connected by gears. The fuel-air mixture was produced by a carburetor. This resulted in a high fuel consumption !
    hope you got what you were looking for ๐Ÿ˜’
  • 4d1
    4d1
    a deltic engine layout: as can be seen,three cylinders and six pistons..(.two in each cylinder )
    [โ€‹IMG]
  • Adil saleem
    @adil-saleem-irIIu3 • Nov 6, 2009
    Very nice 4d1.Very informative indeed.
  • juma1987
    @juma1987-ukh0ej • Nov 7, 2009
    Nice post and information!! :smile: So how this system work compared with the normal engines? i mean the efficiency of it, do you have some numbers?
  • tashirosgt
    @tashirosgt-7BsIre • Nov 8, 2009
    The site #-Link-Snipped-# explains many innovative engine designs. Many articles on the Peswiki are about things that are crackpot or fraudulent, but the articles on engines tend to be about devices that might work.
  • mutley
    @mutley-7zOklN • Jan 13, 2010
    I will be having two pistons firing at the same time on a four cyclinder engine to try and get the torque up, its a suck it a see project. will also have a second engine that will be electric and around 250 nm as a boost as will be pulling a way in 4th gear/ 1:1 of the crank to wheels
