@prototype-G9Gn5k • Jan 16, 2013
Certainly not. The virus present on your laptop is meant to run only in windows environment and they will be inactive at other places. However, it could happen that they migrate to other computer if you connect your mobile device there. Rest assured that they cannot impact your mobile device.
There are very few viruses, most were made to run on Symbian S40 platform and some for S60. Few are emerging for Android as well and Android might get be targeted more due to its increasing utility.
Rest of the phones which doesn't run those are not susceptible to viruses. -
@pikachu1994-UcQIIJ • Jan 16, 2013
Mine is not android.it is nokia c2-02.So no problem?Can't a memory get affected by a virus.?
@rahul69-97fAOs • Jan 16, 2013
I think it is actually possible!!. Many phones use Java, and similar technologies which are common to both Mobile Phones and PC's, so it is better to scan the folders where u transferred files and be sure not to infect your phone 👍
rahul69I think it is actually possible!!. Many phones use Java, and similar technologies which are common to both Mobile Phones and PC's, so it is better to scan the folders where u transferred files and be sure not to infect your phone 👍
Umm no. The other java phones are not actually affected. Only Symbian S40. Besides a virus working on windows could never affect any phone till date. The technology is same, but not the hardware configuration.
pikachu1994Mine is not android.it is nokia c2-02.So no problem?Can't a memory get affected by a virus.?
Only thing that is affected is the space. Those stray files will occupy space, that's all. You'll have to clean up them manually.
How to clean it up manually?Can you please explain?
@thebigk • Jan 16, 2013
Understand that a virus is a computer code that is meant for some malicious purpose. If, while copying, you copied the virus files (hidden, or unknowingly) and the virus is able to execute itself in the environment offered by your mobile (mostly dependent on the operating system, firmware, system voids etc.) then your phone stands a risk of virus affecting your mobile phone.
However, there's a 90% (or 99%) chance that this won't be the case always. Most of the viruses are written for the Windows platform and they don't just work 'as-is' in other environments. There would of course be exceptions where the virus files attack specific parts of the software (aka contact lists or messages or phone settings). -
The actual problem is my mobile get switched off frequently.I suspected that it may be due to virus.But it seems that it is not a problem.Then what is the actual reason?The virus that was in my laptop is suchost.exe
@jeffrey-xA7lUP • Jan 16, 2013
Check whether your battery is bulged or not If battery is swollen life of battery is over replacing it is the only apt solution
But if not we can't say with out physical examination -
No the battery is not bulged.But it is frequently getting switched off😔
@lal-R60Xjx • Jan 16, 2013
Try resetting the phone in that case.
Your phone memory will be erased. That means your contacts, messages and all other stuff if stored in your phone memory will be lost.
