cams
mechky
@mechky-jbqpJD โ€ข Oct 21, 2024
1. Any idea what is the base circle diameter of the cam profile used in operating valves of IC engines?
2. How much is the lift of valves normally in IC engines?
  • ISHAN TOPRE
    @ishan-nohePN • Oct 25, 2011
    The lift of valve is very small and depends on the profile of cam. I think, you are trying to design cam.
    Smallest on an average is around 2mm and maximum that I have heard is around 8.7 mm. This might be helpful to you.
    <a href="https://www.tildentechnologies.com/Cams/CamDesign.html" target="_blank" rel="nofollow noopener noreferrer">Cam Design</a>
    <a href="https://www.rbracing-rsr.com/camshaft.html" target="_blank" rel="nofollow noopener noreferrer">Camshaft Technology and Calculations</a>
  • mechky
    @mechky-jbqpJD • Oct 26, 2011
    IssueThe lift of valve is very small and depends on the profile of cam. I think, you are trying to design cam.
    Ok, thanks for your reply.
    I have found that the cams used to operate valves of IC engines are circular arc cams. I am trying to design a circular arc cam with 45 degree rise and 45 degree fall i.e the valve opens at TDC and closes at BDC (the ideal case). Say, I choose the lift to be 4mm.
    Now, how can I determine the other two parameters which are - the least radius of cam and nose radius. Please help me with this.
