C query
ce_neha
@ce-neha-RCoDQE • Oct 25, 2024
Hi ,
Please make me understand the output of the following code:-
#include<stdio.h>
void main()
char *s1;
char far *s2;
char huge *s3;
printf("%d %d %d ",sizeof(s1),sizeof(s2),sizeof(s3));
  • ameyaamu
    @ameyaamu-myoFwJ Aug 24, 2009
    ce_nehaHi ,
    #include<stdio.h>
    void main()
    char *s1;
    char far *s2;
    char huge *s3;
    i know answer of 1st 1 byte,4 byte,4byte
  • M.Pardhu
    @mpardhu-v8KwMM Aug 26, 2009
    THE OUTPUT OF PROGRAM IS
    4 4 4
    😎PARDHU😎
  • gaurav.bhorkar
    @gauravbhorkar-Pf9kZD Sep 1, 2009
    The output is 4 4 4 because every pointer is 4 bytes long irrespective of what type it is pointing.
  • devil_rads
    @devil-rads-pvv1yP Sep 10, 2009
    I just ran the program and it is showing the output as 2 4 4....
    Can u please elaborate your ans...
  • gaurav.bhorkar
    @gauravbhorkar-Pf9kZD Sep 10, 2009
    devil_radsI just ran the program and it is showing the output as 2 4 4....
    The program gives errors on compiling.
    It runs only after modifying in this way
    #include<stdio.h>
    void main()
         char *s1;
         char *s2;
         char *s3;
         getch();
    Output: 4 4 4
    Using dev-c++ compiler. (or gcc)
  • brahmaasthra
    @brahmaasthra-quGsJu Sep 13, 2009
    First one char *str : str is a pointer variable which stores an address of a char datatype. So the size is 2 bytes (default). In which you can address from (0000)hexa to (FFFF)hexa. you cant go beyond that.
    Second one is char far *str: far pointer increases the addressable locations. where you can give address ranges from (00000000)hexa to (FFFFFFFF)hexa. Ex:- for the monitor output the address is 0800 0000 hexa.
    Third one is char huge *str: when far pointer overflows ie gets incremented from (FFFFFFFF) + 1 it again goes to (00000000) hexa. The address is inside the same process.
    But in the case of huge if it gets overflow (FFFFFFFF)+1 it goes to the next process 1 0000 0000 hexa.
  • gaurav.bhorkar
    @gauravbhorkar-Pf9kZD Sep 14, 2009
    char *s1;
    char far *s2;
    char huge *s3;
    What is far and huge ?
  • Sahithi Pallavi
    @sahithi-oJZaYj Sep 14, 2009
    ce_nehaHi ,
    #include<stdio.h>
    void main()
    char *s1;
    char far *s2;
    char huge *s3;
    hey first can you tell me what is far and huge in your program.?
    WINNERS DONT DO DIFFERENT THINGS....THEY DO THINGS DIFFERENTLY....
  • pdpatel
    @pdpatel-TqKKui Sep 16, 2009
    ce_nehaHi ,
    #include<stdio.h>
    void main()
    char *s1;
    char far *s2;
    char huge *s3;
    As per my knowledge:
    This is happen because simple pointer store in ram and far pointer use video memory.
  • Saandeep Sreerambatla
    @saandeep-sreerambatla-hWHU1M Sep 16, 2009
    brahmaasthraFirst one char *str : str is a pointer variable which stores an address of a char datatype. So the size is 2 bytes (default). In which you can address from (0000)hexa to (FFFF)hexa. you cant go beyond that.
    I guess this is the correct answer!!!
