BIOS problem
sushant005
sushant005
@sushant005-tyt4WK Oct 14, 2024
hi frndz,
my first question is,
Q1> IS there any lifespan for BIOS from the date of purchase?
OR
Is it neccessary to update the BIOS after 6 to 7 yrs.
if yes then my second question is,
Q2> what is the process of updating the BIOS?
  • optimystix
    optimystix
    @optimystix-4yMPKC Apr 3, 2010
    sushant005
    hi frndz,
    OR
    1] the BIOS chip in itself doesnt have a fixed lifespan. It is an electronic device and may go kaput even on the 1st day. it all depends on the usage. But a BIOS chip needs to be update with the latest firmware atleast every 2-3 years(considering the smaller tech cycle in recent times).
    The reason behind this is that almost every year newer technologies is arriving for the consumer market and the BIOS needs to be updated about them. For eg. very few motherboards have their BIOS updated with the information for USB 3.0 and thus around next year when you plan to add a USB 3.0 card on your PCI slot, you will need to update the firmware of the BIOS to the latest one to make it work properly.
    Any new information that comes, needs to be written onto the BIOS chip for it to work properly and this is done by BIOS FLASHING
    2] to learn how to flash the BIOS, check the links below
    <a href="https://www.bootdisk.com/bios.htm" target="_blank" rel="nofollow noopener noreferrer">How to flash your bios - BIOS upgrade</a>
    for videos explaining how to flash the bios, search "how to flash bios" in <a href="https://www.youtube.com" target="_blank" rel="nofollow noopener noreferrer">YouTube</a> , #-Link-Snipped-# and other video sites
  • saurabh2486
    saurabh2486
    @saurabh2486-Tr6NOC Apr 7, 2010
    thereis nolifespan as such but if ur having problems after installing new components like updating your processor or RAM then you should update your BIOS as this might make it stable and for overclocking also it is recommended to have updated BIOS
  • optimystix
    optimystix
    @optimystix-4yMPKC Apr 8, 2010
    saurabh2486
    updating processor ? if u mean adding a new one, then it has to be the same type to be fitting on the same socket and as such there wont be a need to update bios for that. a bios update for a processor is not needed unless there's a jump in some technology in the new processor. for example, changing from the p4 to p4 HT would require an update.
    same case with ram. an upgrade in amount of ram of same type doesnt require bios update. remember that if you are on ddr2 your upgrade will be ddr2 only as upgrading to ddr3 will require motherboard change.
    also, its not that an updated bios is recommended for overclocking. The fact is that there are some particular series of BIOS firmware which gives best support for overclocking. Ofcourse these depend on the motherboard and the series of processor one is trying to overclock too. Thus its not necessary to to upgrade the bios to the latest one. For overclocking, one may even require flashing and downgrading to a particular version which gives best support for OC
    bios is a very delicate thing and as such should not be played with. only the newer motherboards have support for easy flashing and updating of the bios.
