Automatic Vacuum Cleaner
vineethjoust
@vineethjoust-NsHh87 โ€ข Oct 18, 2024
hi to all,
i have started a project on automatic vaccum cleaner.i have a doubt that can a gps is used for detecting obstacles in house?or ultrasonic sensor is the better1?
    @thebigk • Jul 24, 2012
    I'd seriously doubt whether GPS would be useful. Ultrasonic sensor should solve the purpose.
    @ramani-VR4O43 • Jul 24, 2012
    Since the speed is low it is best to use an impact sensing accelerometer kind of device used in phones and pads. Cheaper and more reliable.
    @abrakadabra • Jul 24, 2012
    How about using both? Does this help - #-Link-Snipped-# ?
    You might like to check out Cocorobo Vacuum Cleaner #-Link-Snipped-#
  • vineethjoust
    @vineethjoust-NsHh87 • Jul 25, 2012
    ya i have seen coco robo can yo suggest me a best algorithm for that cleaning purpose pls
  • [Prototype]
    @prototype-G9Gn5k • Jul 25, 2012
    Bunch of simple IR sensors will do the job. If you're after something very sophisticated then find the camera and start playing with image processing.
    However, that sophisticated machine is not required for general use. Try IR sensors itself. The simple you keep it, the better you'll be able to understand it. Don't complicate the thing with gps and others unless they are required.
  • shubham_more
    @shubham-more-gvMXxJ • Jul 25, 2012
    is there any other technique for detecting obstacles?
    @ramani-VR4O43 • Jul 25, 2012
    shubham_moreis there any other technique for detecting obstacles?
    I am sure that you have seen those toy cars that go straight till they hit an obstacle and reverse do a small turn and go straight again. There is virtually no feed back control. The motor automatically reverses when stopped. It is rather crude and goes banging into things. A low cost accelerometer will suffice for this application.
    <a href="https://www-bsac.eecs.berkeley.edu/projects/cotsbots/hardware.htm" target="_blank" rel="nofollow noopener noreferrer">CotsBots: Hardware</a>
  • zaveri
    @zaveri-5TD6Sk • Jul 26, 2012
    proximity sensors would be the best.
  • zaveri
    What would be the cost of such a machine
