Are online exams easy to attend?
aarthivg
@aarthivg-HH344f โ€ข Oct 12, 2024
Now a days, most of the government exams are made as online exam. Is it a good scenario for candidate point of view. There is lot of difference between attending an exam in online and writing an exam in paper. Some of them are, for numerical sort of questions there is a chance of making more mistake compared to paper exam.
Bring out your views. Which is better?
    @sarathkumar-FEGRPw • Aug 9, 2013
    I support online exam as it brings less tension to students and there is no point for the correctors to assume the answer as wrong or right.Even gate exam has been changed to online format .
    Is the India had provided stable internet connection to accept online engineering?๐Ÿ˜ฒ
  • aarthivg
    @aarthivg-HH344f • Aug 9, 2013
    CSK AUTOI support online exam as it brings less tension to students and there is no point for the correctors to assume the answer as wrong or right.Even gate exam has been changed to online format .
    #-Link-Snipped-# How do you say, it brings less tension. You can see the time keeps on running at the corner of your screen. It will create tension among candidate?
    Regarding internet connection, when there is an interrupt in network, there is a provision, we can start the exam from where we left.
    @thebigk • Aug 9, 2013
    Easy or not will depend from person to person. I don't think this is a debate topic. Moving it to chit-chat section.
  • lovejeet
    @lovejeet-etHdkD • Aug 9, 2013
    the basic idea was to do it in a more technical way...and since every new technology has some benifits and drawbacks, even online exam has.... but the thing is that we add more comfort to our life by doing the things more technically.... the burden of checking copies reduces, the burden of writing n blabbering a thousand words by candidates reduces........n so margin of error reduces...... bt then it requires a lot of resouces, and failure of power or system may cost a lot.....
    aarthivg#-Link-Snipped-# How do you say, it brings less tension. You can see the time keeps on running at the corner of your screen. It will create tension among candidate?
    Ah ha.You cant point that as a reason.even in ordinary exam we used to refer watch which will aggregate more tension during the exam.In this 21st era we need to cope with all the developments to compete with International standards.
  • rahul69
    @rahul69-97fAOs • Aug 9, 2013
    aarthivgNow a days, most of the government exams are made as online exam. Is it a good scenario for candidate point of view. There is lot of difference between attending an exam in online and writing an exam in paper. Some of them are, for numerical sort of questions there is a chance of making more mistake compared to paper exam.
    I think online exams are better in following ways:
    • Less hassle in marking answers (as compared to marking ovals๐Ÿ˜ )
    • Lesser chances of making mistakes (sometime wrong answers are marked by mistake as the grid of ovals is a little confusion ๐Ÿ˜• )
    • Option for changing an answer after marking (in offline, applying correction fluid doesn't works ๐Ÿ˜› )
    • Better Time Management ( in offline exam, your watch may be late than the exam clock, which you may notice at the end of exam ๐Ÿ˜” )
    • Saves the paper (and hence helps saving environment ๐Ÿ˜’ ).
