Apptitude Questions
Manish Goyal
@manish-r2Hoep โ€ข Oct 25, 2024
1:-You are a landscape designer and your boss asked you to design a landscape such that you should place 4 trees equidistance from each other?Tell me How?
2:-If one tyre of a car suddenly gets stolen and after sometime you find the tyre without the screws how will u make ur journey complete?
3:-How can you measure a room height using a thermometer?
4:-How would you catch and receive a ball in same direction? (Dropping is from north
and receiving from bottom not accepted, as it is 2 directions)
5:-Can you make 120 with 5 zeros?
  • CIVILPRINCESS
    @civilprincess-308hDv Jan 15, 2010
    The questions are tough.
    for the fifth one i think i got the answer :๐Ÿ˜
    (0!+0!+0!+0!+0!)!
    =>(1+1+1+1+1)! (since0!=1)
    =>5!=120
    am i correct :?:
  • Manish Goyal
    @manish-r2Hoep Jan 15, 2010
    Yes you are correct
    Even i also don't know answer of 4th question
    keep trying otherwise i will tell you answer of remaining questions
    @thebigk Jan 15, 2010
    K: Place one tree on the top of hill and others in an equilateral triangle on the slope of the hill.
    K: Each tyre can have three screws each. ๐Ÿ˜‰
    K: By using the thermometer as a scale ๐Ÿ˜
    K: I don't understand this question. ๐Ÿ˜•
    K: cos 0 = 1 ๐Ÿ˜‰ (wink!)
  • Manish Goyal
    yes biggie you are right for 1st and 2nd question only
  • Manish Goyal
    @manish-r2Hoep Jan 16, 2010
    One more question to add you have two candles each will burn for 1 hour individually ie one candle will take 1 hour to burn completely.Now if you are asked to burn both of these candle for 90 minutes ie both candles must burn in 90 minutes?Can you explain me how?
  • cooltwins
    @cooltwins-I5yJpZ Jan 16, 2010
    by melting them and casting them as one we can extend the burning time more right ๐Ÿ˜
    or do you want to make them burn to 90 min each :roll:
    can you please be more specific.... :-o
  • Manish Goyal
    Each candle take 1 hour to complete
    My question is to burn both candles in such a way that both will take 90 minutes collectively
    ie total time should be 90 minutes to burn both
  • Vega
    @vega-Ic42ds Jan 16, 2010
    goyal420Each candle take 1 hour to complete
    Ignite second candle after 30 minutes from first candle ignition.
  • Manish Goyal
    @manish-r2Hoep Jan 17, 2010
    VegaIgnite second candle after 30 minutes from first candle ignition.
    Yeah you are right..
    Let us make it some more difficult .if i say 45 minutes๐Ÿ˜‰
  • ratikagoel
    @ratikagoel-zu8zrf Jan 18, 2010
    goyal420Let us make it some more difficult .if i say 45 minutes๐Ÿ˜‰
    First light up the two ends of the 1st candle and one end of the 2nd candle.
    When the 1st candle will burn out ,then light up the other end of the 2nd candle too
  • Manish Goyal
    @manish-r2Hoep Jan 18, 2010
    ratikagoelFirst light up the two ends of the 1st candle and one end of the 2nd candle.
    Correct answer๐Ÿ˜€
  • ratikagoel
    4th ques:
    If you throw a ball to the any direction ,due to heavy air in opposite direction it return to your place and u can able to catch the ball by not moving from your original place.
  • rajivtiwari
    @rajivtiwari-MaL9qf Jan 18, 2010
    4th ques
    Throw the ball on the wall
    it will rebound and u can catch it standing at your own place in the very same direction
  • Manish Goyal
    rajivtiwari4th ques
    Quite satisfactory answer ..actually i also don't know it's answer but i think you are right๐Ÿ˜€
  • rajivtiwari
    Okay it was kind of easy for me
    I heard similar question few years back which i quite correctly remember
    Although i don't know it was really a aptitude question or my cousin fooling around
    The question was
    Everyone was showed the window of the room.
    and asked to jump from the window
    None of them went ahead
    but a guy climbed on the window pane
    and jumped back in the room
    and he was selected
    So applied kind of same logic
  • Manish Goyal
    The question was
    Yeah i know about this question it was asked in NDA interview once.one of my friend had given this interview but Alas!he was not selected
  • sherya mathur
    @sherya-mathur-cI63wY Feb 18, 2010
    we have two candles have to burn completely in 90 minutes
    we will start second candle after 30 minutes of the first candle
  • sherya mathur
    for 45 minutes start burning the one candle from both ends and at the same time start burning second one from the one end
    lets see after 30 minutes the the first one will completely burnt out
    and second one will out half now
    lit the second end of the second candle it will take 15 minute to completely burnt
  • ramkumar.j
    @ramkumarj-ibyB7O Feb 19, 2010
    goyal420One more question to add you have two candles each will burn for 1 hour individually ie one candle will take 1 hour to burn completely.Now if you are asked to burn both of these candle for 90 minutes ie both candles must burn in 90 minutes?Can you explain me how?
    ans: v have to burn the first candle for half an hr. after that v can burn the second candle. so, at one hr both the candles ll be burned. am i correct?
  • ramkumar.j
    ans: v have to burn the first candle for half an hr. after that v can burn the second candle. so, at 1 hr both the candles ll be burned.
  • ramkumar.j
    ans: v have to burn the first candle for half an hr. after that v can burn the second candle. so, at 90 min both the candles ll be burned.
  • Manish Goyal
    @manish-r2Hoep Feb 20, 2010
    Please read the posts before it's answer is already given
  • naga lakshmi
    @naga-lakshmi-wryexy Jan 8, 2012
    1) Place thermometer perpendicular to the floor and against the wall.
    2) Make a mark on the wall at the top of the thermometer.
    3) Shift thermometer up so bottom is at mark.
    4) Repeat 2) and 3) until close to the ceiling.
    5) Shift thermometer up until it touches ceiling and mark location of highest mark on thermometer to determine fraction of thermometer length for last segment.
    This would give the height of the room in units of "thermometers". This is not a standard unit of measurement, but it is a measurement. If you desire a more standard unit like centimeters, then measure the length of the thermometer and multiply by height of the room in "thermometers".
    Read more: #-Link-Snipped-#
    โ€‹
  • Nidhi Shetty
    @nidhi-shetty-iateMP Mar 12, 2014
    isnt it the same? catching a ball or receiving a ball?
  • Anunay Sinha
    @anunay-sinha-5fdTAV Mar 22, 2014
    he meant throwing and recieving the ball.
    and i think the simplest way is to use the ball in pendulum, push it in any direction, wait for it to reach the extreme position in opposite direction, then recieve it in between. ๐Ÿ˜
  • Nikhitha Pitla
    @nikhitha-hhoYpG Oct 22, 2018
    There are 3 people A,B,C. Liars are of same type and truth speaking are of same type. Find out who is speaking truth and who is speaking false when they say:
    A says, B is liar.
    B says, A and C are of same type.
