Any suggestions to keep room cool..
X-Engineer
@x-engineer-ZsXLni โ€ข Oct 23, 2024
Can anyone give better innovative and engineered ideas(self creatable) ideas to keep a room cool.
I am stressing on self creatable as i dont want AC even i cant afford it.
Location is Hyderabad,A terrace portion facing East.
    @ramani-VR4O43 • Oct 16, 2011
    X-EngineerCan anyone give better innovative and engineered ideas(self creatable) ideas to keep a room cool.
    CEan ISSUE has some ideas on a room cooler. He may be able to help you.
  • X-Engineer
    @x-engineer-ZsXLni • Oct 18, 2011
    Issue?? are u there???
  • ISHAN TOPRE
    @ishan-nohePN • Oct 18, 2011
    The selection of cooling devices vary according to the place of application. For example, in Mumbai, coolers would be of no use due to humid climate. I haven't been to Hyderabad bu assuming that it is away from coastal areas, the climate is generally hot and dry.
    It is great that you mentioned the location. I also want to know the dimensions of your room.
    But while we design something, just an advice to you~ While you are in room just open the windows and doors and start your fan. If you keep your fan on while the room is closed, it will instead make you feel as if in an oven.
  • X-Engineer
    Thanks issue for the response..
    i am exactly following as the same adviced by you.
    open up windows and fan on at times i am there in room.
    But is it ok to start up the fan and open up the windows if i am going out.??
    Anyway I am not looking for a readymade..coolers available in market...NEED TO build up something...(recycling,use of trash things ..anything)
    mine is a single small room..
  • Mr.Don
    @mrdon-92OwlG • Oct 18, 2011
    In Hyderabad It's very cool at night and very hot in the day time because it lies in a hilly terrain. Try using a cool mat since your's a very small room. It will be less expensive and simple to use or else grow some bedroom plants like snake plants,cactus etc. They will make the air refreshing. You can feel better.
  • Anoop Mathew
    @anoop-FRTf1L • Oct 18, 2011
    Try using as minimal furniture as possible. If you've got old stuff, then try clearing them. Don't keep the fans running always, turn them off when its not hot enough (preferably evenings) and instead open the windows and let some fresh air in. The next thing is to clean the room at regular intervals. It's best if you can clear the floor with water on weekends (assuming that your floor is covered with tiles or cement). If you can, it's better to use a mat and sleep on the floor in case the weather gets too humid. You can also grow plants near to your window to keep circulating clean air. Try the typical 'money-plant', it requires less maintenance. ๐Ÿ˜๐Ÿ˜๐Ÿ˜
  • ursplfrnd
    @ursplfrnd-8Ry66s • Oct 19, 2011
    Paint your house's roof with cooling paints ( ask for them specifically in the shops ). They are really worth and the results can be observed quickly and also for a longer time period.
  • ISHAN TOPRE
    @ishan-nohePN • Oct 22, 2011
    X-Engineeropen up windows and fan on at times i am there in room.
    No, you will only waste electrical energy and raise your electric bills. Do it only when you are in the room. This is what I think.
    By the way sorry for late reply. I have a model in mind and you will need a welder to construct it. In a regular cooler, attach the fan with its direction towards the ceiling.
    Above it mount a conical plate so that the air is circulated in 360 degrees and make water flow arrangements on it to keep the wood-wool on four sides wet.
  • Anoop Mathew
    @anoop-FRTf1L • Nov 11, 2012
    A very interesting topic left in the past. Hope to see people use these techniques and comment more on it.
    P.S.: If you see an old post and you feel there's a need for more discussion, just post a reply to that thread, and it'd automatically get pushed to the front.
  • sweet_honey
    @sweet-honey-areuMs • Nov 11, 2012
    This is a childish suggestion, which we did in our summer vacations..
    We used to cover our windows with a sack and kept it wet. This gave a cooling effect to the some of the area.
    We called this as a mini and natural cooler.
  • Saandeep Sreerambatla
    @saandeep-sreerambatla-hWHU1M • Nov 14, 2012
    Ok, I understand this is an old thread but my suggestion is if you are keeping your windows and doors open and staying at hyd, beware of mosquitoes! Use mesh for avoiding it first , then you can think of keeping your room cool or hot whatever ๐Ÿ˜€
    @anoop-kumar-GDGRCn • Nov 15, 2012
    Ironically ... this thread is bumped in winterโ˜•
    @saandeep-sreerambatla-hWHU1M • Nov 15, 2012
    At hyderabad the day is still hot ๐Ÿ˜€ and night is very cool.
