@nishant-patel-aJRVpl • Dec 11, 2012
any idea friends.............................
i don't get it........................... -
@abcd-2NEyMb • Dec 12, 2012
Active high means: 0 = "off" ; 1 = "on"
Active low means: 1 = "off" ; 0 = "on"
Used for Digital Gates like AND, OR, NOT etc., based on the requirement of output. -
@prototype-G9Gn5k • Dec 12, 2012
There are actually various reasons and one could argue.
Active high inputs are those inputs which gets invoked on high (or +5v). When they are not in use, we generally tend to keep them unconnected WHICH IS NOT A 0v CONDITION. Its an high impedance state and external random signals may somehow cause an spike or glitch. This is generally not an problem with data pins but if this happens to be on RESET signal, it'll totally bring failure of the application that was running.
Hence, signals like Reset & crucial control signals are always active low and you keep them tied to VCC when not in use. This ensures that circuit will not face any false triggers like we saw in case of active high signals.
Another reason is, the transition from High to Low is comparatively faster than transition from Low to High. This helps decreasing the propagation delay of the signal & hence increasing the speed. -
@nishant-patel-aJRVpl • Dec 12, 2012
Hmm, that's true.
Thank you for information friend........ -
@abcd-2NEyMb • Dec 13, 2012
[Prototype]There are actually various reasons and one could argue.
Another reason is, the transition from High to Low is comparatively faster than transition from Low to High. This helps decreasing the propagation delay of the signal & hence increasing the speed.I'm wont conform with the faster transition delay. I dont think it will change. Any sources for it.
What you talking about in the first part, i think, is nothing but pulling up mode. Also, give me the reference for this. But, you are partly right. -
@prototype-G9Gn5k • Dec 13, 2012
mreccentricI'm wont conform with the faster transition delay. I dont think it will change. Any sources for it.
What you talking about in the first part, i think, is nothing but pulling up mode. Also, give me the reference for this. But, you are partly right.As I said, one could argue on the reasons...
For reference, I remember it from 2nd year when one of our teacher told us. He told more, but I can't remember all. I saw this thread before, but didn't replied because I am myself not sure on those points but since, there was nothing, I thought its better to give some direction to OP.
Btw, the two transitions are not of same time. There's a little difference for sure, may be small, but it'll be there. So is the energy required for high -> low vs low -> high. -
OK... will be nice if you can find more information about it. Thanks for sharing ๐
