  • Saandeep Sreerambatla
    @saandeep-sreerambatla-hWHU1M • Jan 19, 2010
    To define them..
    Passive component is the one which store or dissipate energy , like resistors, capacitors and Inductors.
    Active components are those which give power like voltage sources.
    To be more clear Passive components dont have any directionality , thus semiconductor devices will come under active components like diode which has a direction.
  • KAPILBEC
    @kapilbec-tmRzSe • Jan 19, 2010
    Basically the passive components are resistors,capaitors,inductors and these do not require any voltage supply.
    Active components are like transistors and linear op-amps which have got current or voltage gain and these use passive components like resistors,capaitors,inductorsand active components are powered by an external voltage
  • piyushh
    @piyushh-O70sb6 • Jan 19, 2010
    pasive components are those which do not provides any gain..while active components are those which provides gain..e.g voltage gain, current gain
