  • AC motor running on square wave
    Voltaire
    Member
    Updated: Oct 27, 2024
    Views: 1.2K
    Hi
    My client wants to run a pump on inverted power. I recommended pure sine but what effect will square wave have on the motor? It is a single phase motor (small) and runs for short periods ca. 15 mins at a time, twice a day. Cap start induction.
    Thanks
  • vasanthmbs
    MemberJul 24, 2010
    it ll run.. but poor efficiency ... get heated soon. slow speed compared to ordinary one..
  • Voltaire
    MemberJul 25, 2010
    Thanks Vasanth
    What about pure sine? I believe that the inverted wave is actually distorted somewhat but I'm guessing that it would be okay. Could you please confirm this? Also; is it possible to run an AC motor on DC power? I can appreciate that start-up would require some work but is it possible in principle?
    Peace
  • aj_onduty
    MemberAug 25, 2010
    The sine wave is more perfect wave in the sense that it has comparitively lesser harmonics than other waves, square, saw tooth, etc. The square wave has a very high amount of harmonics. If we use this in a motor, or any other electrical machine as such, they produce more heat in the machines. This can be explained using electrical humming in the cores.Do a bit of research in harmonics and the electric hum, you will find it out why.
