Abstract Methods at a glance
WARDHAMAN BEDMUTHA
@wardhaman-HBFrS6 โ€ข Oct 26, 2024
Abstract method is a method which does not have any body (i.e. implementation).
  • Abstract class means it can not be extended(instantiated)
  • Abstract method means it should be overridden.
Abstract method examples -
public void erase(); --- ABSTRACT METHOD DOES NOT SPECIFY BODY,NO BRACES ALSO.
Some examples of abstract methods are :
int area();
private String brand();
SYNTAX : (ACCESS MODIFIER) RETURN TYPE NAME OF METHOD() SEMI COLON
  • Access modifier is optional
  • Return type is mandatory
  • Method name is mandatory
  • No Braces ,Should end with semicolon
If a method inside a class is declared as abstract ,that class should be marked as abstract,other wise it will throw an error.
package Test;
public class Board {
int height;
int width;
abstract void write(); --error message will be shown as "The abstract method write in type Board can only be defined by an abstract class"
