  • Abrasive water jet cutting
    ankush sharma
    Member
    Updated: Oct 26, 2024
    Views: 1.4K
    i have gone through so many research papers but i didn't find that any paper on abrasive water jet cutting of High carbon steel.
    can we cut High carbon steel with the help of Abrasive water jet machine?
    if yes,than what parameter and range of various parameters should consider for better surface quality.and if no then why?
    please give e solution asap.
  • Jeffrey Arulraj
    MemberOct 17, 2012
    The intensity of water flow along with the pressure with which the water is forced out
    Other words the width of the nozzle is the major factor
  • zaveri
    MemberOct 19, 2012
    water flow velocity, along with the pressure in the pump, and also the distance between the nozzle tip and the workpiece surface.
  • Kedar Malwadkar
    MemberDec 9, 2012
    zaveri
    Adding to this, i'd say the type and size of abrasive material would matter a lot.
  • Jeffrey Arulraj
    MemberDec 9, 2012
    Kedar Malwadkar
    Hey buddy we are using water jet as an abrasive here How can we know what type water takes 😨
  • Kedar Malwadkar
    MemberDec 9, 2012
    just water can't cut any metal.
    we need to add some abrasive material such as sand/Calcium carbonate. and then throw this mixture through jet.
  • Kedar Malwadkar
    MemberDec 9, 2012
    Refer this- <a href="https://en.wikipedia.org/wiki/Water_jet_cutter" target="_blank" rel="nofollow noopener noreferrer">Water Jet Cutter</a>
  • Jeffrey Arulraj
    MemberDec 9, 2012
    Hey friend I am not into this mach thing much But Fine sand is not a real strong abrasive and they have the potential of clogging the nozzle Can some more idea be given here. I don't get it
    Both CaCO3 and sand have clogging nature due to insoluble nature then How is it possible to maintain a very fine nozzle tomaintain the pressure and Velocity head
    PS: link has explained thanks
  • zaveri
    MemberDec 9, 2012
    Water jet machining actually makes use of the potential energy of a flowing water jet, and is used to cut only softer materials like leather, wood, cloth etc.
    this type of machining is employed by all German car makers to manufacture the car upholstery.
    Abrasive jet machining is a different thing altogether.
  • Kedar Malwadkar
    MemberDec 9, 2012
    But #-Link-Snipped-# asked about "Abrasive water jet machine" .
  • CE Designer
    MemberDec 14, 2012
    Water jet cutting can be used for softer materials like rubber. For steels Abrasive Water-jet cutting, which uses water with an abrasive sand mixed in it will work fine.High speed and high pressure will give you the best surface finish.
