@reachrkata-FOcqhH • Jan 22, 2007
If you refer to any text book indicating the internal construction of a 555 timer, you'll see that Vcc is divided internally using 3 resistors to get 2/3 Vcc and 1/3 Vcc used later in comparators.
The values of these 3 resistors are 5 kilo Ohm each and hence the name 555.
@jerry-5wPKU7 • Jan 22, 2007
reachrkataIf you refer to any text book indicating the internal construction of a 555 timer, you'll see that Vcc is divided internally using 3 resistors to get 2/3 Vcc and 1/3 Vcc used later in comparators.
😁Perfect! 😁 The timer gets its name from the resistors!
Jerry
