360 degrees.
This is not exactly a puzzle.I have invented this myself.
Have you ever wondered why we have a circle of 360 degrees only? When we can have it of 100 degrees,according to centi-scale?
I think the answer is Earth.Earth rotates around Sun in 365 days with an eccentricity of 0.016.So we can assume it to be nearly 0 eccentricity.Hence we can safely assume this elliptical path as nearly a circle.
In short
Ellipse with an eccentricity =Circle
of 0.016(365 days)
Hence for calculation perpose we can take it as 360 degrees.
Correct me if I am wrong.๐
In short
of 0.016(365 days)
PraveenKumar Purushothaman
I still don't get you! 360 and 365, how are these two different figures related?ishutopreThis is not exactly a puzzle.I have invented this myself.
In short
of 0.016(365 days)
Correct me if I am wrong.๐ -
Ankita KatdareI've been wondering why the ancients kept a standard circle only to 360 degrees.
๐
I figured that it had something to do with the Babylonians, who used a base 60 number system.
I found what I was looking for in a book called "A History of Pi" by Petr Beckmann, a mathematician from Czechoslovakia.
Here's the passage:
In 1936, a tablet was excavated some 200 miles from Babylon. Here one
should make the interjection that the Sumerians were first to make one of
man's greatest inventions, namely, writing; through written communication,
knowledge could be passed from one person to others, and from one
generation to the next and future ones. They impressed their cuneiform
(wedge-shaped) script on soft clay tablets with a stylus, and the tablets
were then hardened in the sun. The mentioned tablet, whose translation
was partially published only in 1950, is devoted to various geometrical
figures, and states that the ratio of the perimeter of a regular hexagon
to the circumference of the circumscribed circle equals a number which in
modern notation is given by 57/60 + 36/(60^2) (the Babylonians used the
sexagesimal system, i.e., their base was 60 rather than 10).
The Babylonians knew, of course, that the perimeter of a hexagon is
exactly equal to six times the radius of the circumscribed circle, in fact
that was evidently the reason why they chose to divide the circle into 360
degrees (and we are still burdened with that figure to this day). The
tablet, therefore, gives ... Pi = 25/8 = 3.125.
So that's who gave us the 360 degrees in the circle. ๐ -
PraveenKumar PurushothamanAKD, its too much confusing to understand... But some great logic is there behind this and the compass based clock... ๐
shiwa436
Bit confused with this..AbraKaDabraI've been wondering why the ancients kept a standard circle only to 360 degrees.
๐
Here's the passage:
ISHAN TOPRE@AKD:Can we say thay earth traces a n arc of approximately 1 degree in 1 day around the Sun?
Yeah, but even then it should be 365 degrees and not 360 right?ishutopre@AKD:Can we say thay earth traces a n arc of approximately 1 degree in 1 day around the Sun? -
ISHAN TOPREWell praveen, earth rotates around the Sun in an elliptical path of eccentricity 0.016.
So we can approximate those extra 5 days as negligible
365 days = Circle of 360 deg
with e=0.016 with e=0
that is why 1 day = 1 degree(Approx) -
PraveenKumar PurushothamanSo, 0.016 is equal to 5 days! ๐
silverscorpionWell, as AKD said above, circle having 360 degrees is because of Babylonians using sexagesimal system (base 60).
It has nothing to do with the number of days in a year or earths' eccentricity (or so I believe ๐ )...
It's due to the same reason that one degree is divided into 60 minutes and one minute into 60 seconds.
But as to why a circle is having 360 degrees and not 60 degrees, I have no idea. -
PraveenKumar PurushothamanWhat is the name of the instrument which uses this degree system and sun's direction to measure the time? It has a right angled triangle from the centre and it is supposed to be placed facing east. Forgot its name, does anyone know? I am not sure whether it is a compass or something.
durga ch@ praveen - its a sundail
Oh thanx, yeah. Forgot totally... ๐durga@ praveen - its a sundail -
mitul00719The circle is limited to 360 degrees becoz of base 60 system...try using base 10.nd work it out
PraveenKumar PurushothamanBase 60 system? If its base 360 system, then its accepted that 360 + 10 = 10. Can you explain?
Saandeep SreerambatlaHere is a simple explanation.
Check this. #-Link-Snipped-# -
PraveenKumar PurushothamanNice explanation man!!! Base 60 is understood as in Seconds and Minutes... ๐
ISHAN TOPREGreat Explanation ES! good finding. After all ancient knowledge helps.
Can I ask you one thing? How is the answer different from my previous reply. If you look closely, please explain. ๐ -
mitul00719how did the ancient know that the earh rotated in a circular manner but not ellpitcal. or any other.?
i dont understand that how could hav they calculated the 360 degrees becoz eath does not move in a perfect circular path...
any1 clarifying for me? -
Simple, the circle or sphere is the basic shape of anything... Consider a water drop, it is sphere in shape. Another example is when you take a cube and rotate it. It becomes a sphere. By this way, they would have calculated that the shape of Earth is round, as Sun comes and goes, but it is static. But still, I have that doubt of 360 thingy! ๐mitul00719how did the ancient know that the earh rotated in a circular manner but not ellpitcal. or any other.?
mitul00719thanks for clarifying ๐
The world is moving the past-PC era and soon we'll see touch screen devices everywhere. There's lot of innovation happening on the display technology and it seems that Quantum Dot...
Definition: Within the elastic limit of a solid material, the deformation, produced by a force of any kind is proportional to the force.
Has anyone wondered why the definition has...
S&M Consultants is one of the upcoming names in the Oracle Fusion Middleware (OFM) Space. It has a team of experienced and certified OFM developers, who have sound understanding of...
Hello i m 2nd yr Ec student i m very confused in which field should i do my summer training and also how get in iitk for summer training........
We never knew we'd need a tiny slate with a magical touch screen on it that'd begin to replace our laptops. However, we all must agree that gadgets are evolving...
