@balaseven-uQqjBy • Jul 9, 2008
Hi kuku,
Make sure that u have reverse biased the ZENER diode.Moreover,your expected regulated output should be same as zener diodes reverse breakdown voltage or zener voltage.For example, If your expected regulated output is 10V,you should select diode which has zener voltage as 10.
Hope this helps u. -
kuku OP
@kuku-kmuwiI • Jul 9, 2008
Hi BibB,
Thank for that.
But everything is ok.Then also it fails. -
@sauravgoswami-UAfTlI • Jul 10, 2008
why dont ya use high-ampere diode say HV135 or simply increse the capacitor load
@balaseven-uQqjBy • Jul 10, 2008
Kuku,
whats your input voltage,is it 230V AC?
i think,you r trying to get the step down transformers's funtion without using transformer,isn't it?if you dont mind,post your circuit,i will analyze and try to tel the reason. -
kuku OP
@kuku-kmuwiI • Jul 10, 2008
hi Sourav,
Thanks for reply. Actually i think its not taking so much power with calculation its hardly reaching 1W. -
@sauravgoswami-UAfTlI • Jul 14, 2008
hey if u need DC supply then use a bridge rectifier as it devides the load between the diode,if u wanna regulate the AC voltage then diode is not suggested but why u aint using a transformer???...its the best way to regulate AC...
