@saandeep-sreerambatla-hWHU1M • Mar 18, 2012
You can do this may be it works,
consider you have 10 rows and you have to delete 8th row.
Then using update query , update the content of 8th row with 9th and 9th with 10th.
THen update 10th row with null values ๐
This is the answer I would have given!
I think there will be a better answer as well!! -
@dancer-engineer-EJ8rGI • Mar 21, 2012
#-Link-Snipped-#, the solution may not be feasible if I have to delete the 2nd row from a table having 100 rows.
Updating the 2nd row with NULL will do the required job.
Another solution is to update the row to be deleted with 'zero-length string', i.e. "". -
@kr-at-nsngu-XqzcfU • Mar 21, 2012
Dancer_Engineer#-Link-Snipped-#, the solution may not be feasible if I have to delete the 2nd row from a table having 100 rows.
Updating the 2nd row with NULL will do the required job.Updating the data with Null values will not permanently delete the row/data.
Another solution is to update the row to be deleted with 'zero-length string', i.e. ""."Zero" will be considered in this case.
There could be more feasible answer ๐ ??.
seems to be the toughest question. -
K!r@nS!nguseems to be the toughest question.
Yeah. Could be a tricky one too.
Could the answer be as 'not possible to permanently delete record using update query'? ๐
#-Link-Snipped-#, do you have any solution? -
@praveenkumar-66Ze92 • Mar 21, 2012
Hi, Thanks #-Link-Snipped-#! Yes, one possible way is to use the UNION operator...
Try this:UPDATE `table` SET `abc` = `cde` WHERE 1 = 0 UNION DELETE FROM `table` WHERE `condition` = `value`;
This works for sure... ๐
@neeraj-iAaNcG • Mar 21, 2012
But you are using delete query in it right??
Nick_SharmaBut you are using delete query in it right??
But its an update query, as they haven't said anything about using other queries... It should be a single update query... That's it... ๐
@saandeep-sreerambatla-hWHU1M • Mar 21, 2012
Great Praveen! when I answered it I didnt think of the null record. my solution will delete only values not the row!!
English-ScaredGreat Praveen! when I answered it I didnt think of the null record. my solution will delete only values not the row!!
Thanks ES!!! ๐
@anoop-kumar-GDGRCn • Mar 21, 2012
@#-Link-Snipped-# : As I checked your solution is not working.
Here is using merge statement.
its working.
Merge INTO table123 t1 using (select * from table123 where ID1 ='DEL_IT') t2 ON (t1.ID1 = t2.ID1) WHEN Matched then update set t1.ID2='YourValue' Delete where (t1.ID1 ='DEL_IT')
ianoop@#-Link-Snipped-# : As I checked your solution is not working.
its working.
Thankz but is this a single query???
Still it is not an UPDATE query... Its a MERGE query!!! ๐ My query needs to be checked! ๐
Yes its single query using merge..
first it is update the same row and then deleting it. So it is a update query.
Simply, merge satatment is used to update a table from a source. -
sorry can't able to add semicolon in above post.giving some error
ianoopsorry can't able to add semicolon in above post.giving some error
No that's what... Its a MERGE query and not UPDATE query...
@prashant-munshi-qp7Wu5 • Apr 30, 2012
This answer probably is much late. But those answers which have been given here before are none a workable solution, for sure. I would need to know how and in what context this question was asked. I believe there is no straight forward answer to this question or rather there may be no answer, the interviewer may be just playing a prank. SQL is not known to posses any such syntax u could delete a row using update verb (command).
@praveenkumar-66Ze92 • Apr 30, 2012
Prashant MunshiThis answer probably is much late. But those answers which have been given here before are none a workable solution, for sure. I would need to know how and in what context this question was asked. I believe there is no straight forward answer to this question or rather there may be no answer, the interviewer may be just playing a prank. SQL is not known to posses any such syntax u could delete a row using update verb (command).
So, is there a solution for it?
In my opinion there is none, the question is nothing but a prank. But every person is limited by his / her experience and knowledge he / she has, so my comments be taken with due modesty. I shall still keep on doing research however. But for now I have no option but to reject the question.
