Write a program to generate RPN expression
OK, this may be many might be aware of (atleast CS?IT engineers)
Reverse Polish Notation (RPN) is a mathematical notation where every operator follows all of its operands. For instance, to add three and four, one would write "3 4 +" rather than "3 + 4". If there are multiple operations, the operator is given immediately after its second operand; so the expression written "3 â 4 + 5" would be written "3 4 â 5 +" first subtract 4 from 3, then add 5 to that.
Transform the algebraic expression with brackets into RPN form.
You can assume that for the test cases below only single letters will be used, brackets [] will not be used and each expression has only one RPN form (no expressions like a*b*c)
Input
The first line contains t, the number of test cases (less then 100).
Followed by t lines, containing an expression to be translated to RPN form, where the length of the expression is less then 400.
Output
The expressions in RPN form, one per line.
Example
Input:
3
(a+(b*c))
((a+b)*(z+x))
((a+t)*((b+(a+c))^(c+d)))
Output:
abc*+
ab+zx+*
at+bac++cd+^*
Source: <a href="https://www.codechef.com/problems/ONP/" target="_blank" rel="nofollow noopener noreferrer">ONP Problem | CodeChef</a>
Thanks for giving a try! I will also come up with my program just stuck up at present.
